Question about Acura Mdx Double-din Radio Install Dash Kit 7866b
Need double din kit for 2012 acura mdx - Acura Mdx Double-din Radio Install Dash Kit 7866b
  • 1348 Answers
SOURCE: acura mdx 2005
30000 miles.the owners manual will tell you exactly.most honda are 48000 km,exception is the cvt type transmission which there is no service done.
Posted on May 26, 2009
co7196
  • 3433 Answers
SOURCE: 2006 Acura MDX bluetooth stopped
Bluetooths have batteries, Rechargeable. If it won't hold a charge replace the batt.
Posted on Oct 16, 2009
  • 3 Answers
SOURCE: Need to reset the code my Acura MDX navigation
check the side of the glove box. my TL has it on the outside side panel as you look from the driver side. my honda prelude had the code there as well. hope this helps
Posted on Apr 30, 2010
  • 41 Answers
SOURCE: acura mdx am radio problems
there is a tsb on this one..this issue is most of the time linked to poor contact ,corrosion in the wiring of the antenna, damaged or loose antenna. It is located on the rear of the roof and to access the wiring, the head liner must be pulled down.
Posted on Oct 12, 2010
  • 478 Answers
SOURCE: acura mdx
SOUNDS TO ME LIKE A BAD CO2/LAMBDA SENSOR
Posted on Sep 06, 2012
Removing radiator from 2003 mdx
Try the instructions at the link, it is a 2005 model but should be useable for the 03 model. http://ww2.justanswer.com/uploads/EB/ebrock63/2012-12-19_010536_rad.pdf
Oct 12, 2016 | 2003 Acura MDX
My mdx alarm system would not stop going off
Is this a factory security system you are having issue with?
Oct 04, 2016 | Acura 2012 MDX AWD Tech Pkg
Trip Meter not working.
Odometer and Trip Meter Stopped Working - AcuraZine Community
acurazine.com/forums/.../odometer-trip-meter-stopped-working-757772/
Dec 29, 2009 - The tech said he has seen the odometer & trip meter not workingbeing ... I have a 1997 TL and the same exact thing happened to me today. speedometer,trip and odometer not working
Aug 5, 2012
Cannot reset Trip A or Trip B on New 2012 MDX
Aug 1, 2012
Trip meter resets itself
Jul 25, 2012
Trip Computer Reset feature (with refuel) question..
Dec 19, 2009
More results from acurazine.com
Acura TL odometer trip meter not working Questions ... - Fixya
www.fixya.com/tags/odometer_trip_meter_not_working/cars/acura/tl
Dec 15, 2015 | 1997 Acura TL Series
2005 Acura mdx passenger side headlight out, bulb ok, fuse ok, what next
Check for power and ground at the headlight plug. Test lights are cheap.
Oct 17, 2014 | 2005 Acura MDX
Air bag sensor replacement on 2003 acura mdx
You need to have the srs code read, to see what is setting it.
Aug 09, 2014 | 2012 Acura MDX Base 4dr SUV 3.7L V6 AWD...
Can you buy a 2002 acura mdx with 187,000 miles for $6,500? Is it a good deal, or not?
the tmv (true market value) used by dealers- base vehicle in good cond w/under 90,000 is about $ 7,900 this car has double the miles and you would know the condition and options--
Nov 24, 2009 | 2002 Acura MDX
My 2001 acura mdx driver side door won't close
THE DOOR CATCH HAS A DOUBLE "C" THAT HOLDS THE DOOR CLOSED. FIRST TAKE A SCREWDRIVER INSIDE THE "C". USING THE HANDLE ON THE INSIDE, PULL THE HANDLE AS IF YOU WERE OPENING THE DOOR AND AT THE SAME TIME, OPEN THE DOUBLE "C" WITH THE SCREWDRIVER. I HOPE THIS HELPS. THANKS FOR USING FIX-YA. PLEASE FEEL FREE TO KEEP ME POSTED. GOOD LUCK
Sep 02, 2009 | 2001 Acura MDX
Open Questions:
Rearview backup camera not working, flashing screen. Not tailgate camera wire problem. Please Click "Want Answer" to get this question answered. Just to start out, I have replaced the entire camera wiring harness so a broken wire there should not be the culprit.I've had the MDX for a 4 years and the camera and Navigation have not worked for years. I recently replaced the Navigation unit hoping it would also fix the camera issue. Now the Nav is working as it should but the camera is still not working, still flashing between black and white with no picture visible. I have been able to bring up the brightness menu through the nav screen to adjust up or down screen brightness but it has no impact when I increase or decrease the brightness. I've read a lot on about every possible forumn. When my MDX is in reverse, my backup camera does not work. I did research and find the most common reason for failure related to severed wires (red wire usually) in the passenger side boot between the tailgate was broken. Mine was broken too and I started with soldering the wires together but that didn't work. I then purchased ($28) a new OEM Rearview Camera wiring harnes from Acura. I replaced the entire wire harness to solve the issue but the camera still does not work. All fuses are checked and good, reverse lights work, light bulb in hatch door is working. No damage in wires between the Camera and new wire harness. That leaves me with a possible bad Rearview control unit (havent been able to find this yet) or a bad camera assembly. Maybe some other internal wiring issues between display and control unit. I've tried to take the passenger side interior panels off but saw it was going to be a pretty big job so I thought I should ask before I gave up. Please help. I have a cheaper volt meter, has red and black lead, but haven't learned how to use or read it yet. I wish I knew. The main difference I have noticed between others that have been able to fix their problem by reconnecting the wires is that their screens are blank, which indicates they just aren't getting power to the camera. My screen flashes between white and black about every second.
May 25, 2016 | Acura 2004 MDX Touring with Navigation S
Acura Mdx Double-din Radio Install Dash Kit 7866b Logo
60 people viewed this question
Top Acura Car Audio & Video Experts
xxxxxx xxx
afairman1927
Are you an Acura Car Audio and Video Expert? Answer questions, earn points and help others
