Question about Franzus Travel Smart& International Converter Kit
Check if franzus travel converter working
How can I check if converter will change 220v to 110v; how can I fix it if not working; how do I know if fuses are good?
Can i convert a pfaff select 4 from europe (220V) to 110V?
Aren't there converters available for people who travel?
Oct 08, 2015 | PfaFF Sewing Machines
When traveling to countries with 220 voltage, is there any danger of overheating, or should I use a voltage converter?
You simply can't use any 110V device at 220V, be it a cellphone converter or a food mixer.. Some artifacts have a switch to be used at 110/220 and those, once changed to 220V, can be used.
Jul 01, 2015 | Food Mixers
Is it possible to use a Franzus 1600 watt converter and plug which I purchased several years ago?
This converter is intended for devices that could care less about the waveform of the "110 volt AC" that they receive, such as items using the current to heat things: irons, hair dryers,...
I would recommend strongly AGAINST using it for "delicate" electronics that really want/expect a clean AC waveform to rectify.
Recommendation: DON'T use it.
Apr 28, 2014 | Franzus Travel Foreign Voltage Converter...
Bought from usa to australia changed to recomended fuse, fuse blows as soon as turned on the unit was brand new any ideas ?
hi,
You have to check the working voltage of the adapter of you device. If it purchased from US then it will be 110V. I think the Line voltage in Australia is 220V.Also You have to check is there is any input voltage selector in the in its adaptor . If it there you have to change it to 220V. If there is no such selector then you have to buy a 220v to 110v converter .Then connect the out put of that converter to to your device. You can by this converter at any electronic spare part shope near to you. Or you have to by a new 9V 1.3Amps AC adaptor. When you going to by the converter or a new adaptor take the device. If so they will explain you how to connect the converter or adaptor . By changing a fuse you can't change the operating voltage. If The adapter is designed to use in 110V then the fuse will blow. If you change the fuse and make more experiment with it it will make the full system useless.
ok
Aug 05, 2011 | Lexicon MX200 Multi-Effects Processor
No display on power up got as gift it is 110v but
Did the 220v converter got too hot? Try another larger 220v converter?
Nov 15, 2010 | Vizio VA26L 26 in. LCD HDTV
I wanted to purchase a Bose companion 3 set from the US through ebay. i wanted to know whether they work on 220V and if not how can I make them work at 220V.
Since this unit dose not come with power adaptor. It has direct plug in in to the port behind the sub-woofer unit and other end to the wall outlet. Is there any way to convert the power supply from UK to US (220v to 110v). For example Desktop PCs have a switch behind every desktop unit to change power from 110v to 220v or vise versa.
Anyone has any idea how to make this happen in Bose Companion 3 system.
I bought it from UK and now moved to US and I want it to work in US.
othervise use waltage adapter to use it
Aug 08, 2010 | Bose Companion 3 Computer Speakers
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
Franzus Travel Smart& International Converter Kit  Logo
42 people viewed this question
Top Franzus Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Franzus Electrical Supply Expert? Answer questions, earn points and help others
