Question about Kitchen Ranges
Whirlpool accubake oven reads default detected
Default detected press start to try again
Agent Matt
  • 8 Answers
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Posted on Apr 07, 2008
  • 126 Answers
SOURCE: Broiler will work, but oven wont
Could be the bake igniter is bad and broil igniter is still good. may need to replace the bake igniter you will need a complete model number off range to determine the part number of the igniteryou may need.
Posted on Jan 07, 2009
aborcass
  • 2651 Answers
SOURCE: What does E2 - F3 - code mean on a Whirlpool Accubake Gold??
F3 - E2 Oven too hot Replace oven temperature sensor
Posted on Jan 11, 2009
SOURCE: whirlpool accubake oven will not heat after self clean cycle
I had the exact same thing...thermostat..
Posted on Jul 11, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool Gold Accubake Duo. ''E4 - F3'' or ''E0 - F3''
HI. These codes are an indication of oven temperature sensor failure. The sensor is damaged. This will not allow for proper operations. The affected part must be replaced, asap.
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner.It will look like a 4 inch long slender probe. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Posted on Dec 28, 2009
Testimonial: "Thank you so much. This is a job that my husband can do to fix it."
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Whirlpool Accubake Wall oven pre heat but temp goes 350 and downwards when pressing temp up
I am not sure about this, but sounds like a connector is on backwards or in the wrong place.
Nov 26, 2014 | Whirlpool Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
I was self cleaning mt oven and now it stays locked , and displays a code of e1 in red on left side of display and f 5 on right side of display whirlpool self cleaning oven with accubake system
I pressed the start button for 5 seconds and the lock symble came on than I pressed the start button again for 5 seconds and the oven unlocked and all is well
Jan 07, 2010 | Whirlpool Ovens
Whirlpool oven accubake system
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Jul 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool Accubake oven super capacity series 465
Press and hold the Broil button for 5 seconds. You will see the c change to f. THen change the temp to what you need.
Dec 21, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Dec 18, 2007 | Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
