Question about Craftsman Sears 139.18190 18190 Compatible 315 MHz Mini Key Chain Security Remote Control
Fix garage remote control
Part fell out and don't know where it goes?
Remote for appollo 1996 fell apart need to know how to reassemble
Replace it, they don't provide repair instructions for this type of device.
Nov 05, 2012 | Cars & Trucks
Emerson TV SN: 011-40401078 Model TC1379 The power switch came loose and fell inside. I don't know if it broke or came apart. I only found the plastic piece and don't know how it attaches...
Well somtimes buttons break off of tv's because that they are old so its not worth fixing an old tv
now a days most people just buy a new one then instead of fixing the old one. Or you could find someone that fixes old tv's too. To find an old tv like the phiilps one we used to have you would probally need to go to an antique store or and a pawn shop or a secondhand store or a garage sale then. Or the dump because sometimes people put things in the dump like CRT tv's to get rid of them then.
Aug 22, 2011 | Emerson TC1351 13" TV
I have 2 problems with my Craftsman Garage Door opener: 1. I have a 2 door-garage & 2 remote controls Both remote controls can open one garage door (since they were originally programmed). They...
I can't help you on programming.
If the door goes up as soon as it touches down, it is going too far down.
Locate the adjustment on the box on top. There should be four adjusters:
Door down amount more or less
Door up amount more or less
Force down more or less
Forch up more or less.
Turn the Door down amount toward the "LESS" or "-"
Let me know how you do.
Gary
May 31, 2011 | Garden
How to set acsctg type 2
There is a button on the motor head you can press. Press it then press the button on the remote 3 times and try it. If not try it again. Genies are bad for not coding in the first time. Make sure there are new batteries in it. Thanks BB
Jul 19, 2010 | Genie Company IntelliCode GICT390-1BL...
I have a craftsman garage opener and my lock won't work
The wireless keypad should work but the remotes should not. I suspect a bad wall control but there is a possibility of a bad logic board. If you have a neighbor with a 3 button wall control see if they will let you borrow it to eliminate that problem. Just make sure you note which wire goes where on the back of the control. They are color coded.
May 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsmand garage door opens radomly
More than likely, someone else has a garage door system with the same or similar frequency. You may want to try to reprogram the code on the unit and remote devices.
I Can Fix It!
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
My remote fell off my bed and fell apart and now doesnt work. its an rca tv 244889 remote control. can someone please help fix it. Thanx
You should be able to fix the remote yourself with a screwdriver. if the plastic has broken of the circuit board has broken all you can do is replace it im afraid.
Mar 10, 2009 | RCA 244889 Remote Control
Garage Door Opener Wireless Keypad Button Fell Off
You can order replacement parts from searspartsdirect.com. Depending on the model you may be able to order just the pad or you have to replace the whole thing. Thanks BB
Oct 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Sears 139.18190 18190 Compatible 315 MHz Mini Key Chain Security Remote Control Logo
Top Craftsman Building Materials Experts
hpgwva
L Pfaff
L Pfaff
richie46
Are you a Craftsman Building Material Expert? Answer questions, earn points and help others
