Question about Technics SL-BD22 Turntable
Just changed the belt on a technics bd 22 turntable and fed it correctly through the side spindle. When I move the tone arm over the platter turns but there is a rubbing noise under the platter that won't go away
    Sergeant:
  • 432 Answers
Remove the platter and watch closely if a part sticks out, it has to
Posted on Sep 21, 2014
  • 3 Answers
SOURCE: technics mk2 tone arm replacement
once you soldered to circuit board place - this might help Advanced Tonearm stuff Tightening the suspension on your tonearm Some TT's have tonearms which seem to be loose. If you grab the tonearm and pull it gently back and forth and it seems loose you can tighten it. It shouldn't move at all. A loose suspension can severely affect it's performance - from jumping needles to binding. It's pretty easy to tighten the suspension. You'll need a small flat screwdriver and a large one. Use the large one to loosen the outer locking screw on the top of the pivot point. Now use the smaller screwdriver to loosen up the smaller screw. Put a drop of oil where the bearings are (under that top support on the other end of the adjustment screw) so that it doesn't bind. Now tighten the small screw slowly until it just contacts the bearings. Adjust the tightness so the tonearm doesn't wiggle if you pull on it but leave it loose enough for the tonearm to pivot freely without binding. Adjust carefully and don't overtighten otherwise the bearings will be damaged! When done, tighten up the locking screw. Tightening up the headshell locking ring Have you put on your headshell, twisted that knurled tightener at the end of the tonearm as tight as possible and have found that the headshell still moves around? What will happen is that the headshell won't sit parallel to the record but may be tilted as a result of twisting of the headshell. This usually occurs when you change headshells a lot or if you've had your turntable for a while, and can contribute to needle jumping so here's what you do to fix it. First read 3.2 on base disassembly. Remove the rubber base. There will be this big piece of hard black plastic covering almost everything. You'll need to remove it. To remove the tonearm assembly look for three screws (all formerly under that black plastic) and unscrew them. Be careful not to drop the tonearm when you remove that last screw! Now, remove the tonearm assembly from the rest of the 1200, and look at the bottom of the tonearm where the headshell is put in. There will be two tiny philips screws there. Get a jewelers screwdriver of the CORRECT size and tighten those up. Put the headshell on and try wiggling it to make sure everything is right. Now put your tonearm back on and close everything back up. hope this helps peace DJ Nyce
Posted on Jul 25, 2007
djproaudio
  • 515 Answers
SOURCE: High-pitched, repetitive squeaking noise from under platter on 1210MK2
Make sure there is nothing on the magnet part of the platter. Also, sometimes, the screws that hold down the plastic protective cover underneath the platter might not be seated all the way. Lastly, look at the bottom of the magnet, and make sure that it is in tact, and nothing is bent, broken, or cracked.
Other than that, try switching out the platters from your other turntable, and see if the problem persists. You need to rule out what it is not, before you can proceed with finding out what is the problem. So if the noise moves to the other turntable, you know the issue is with the platter. If the noise remains on the same turntable, then you can rule out the platter being the culprit, and can isolate the issue to the turntable. I've never heard of this, and I've fixed well over 3000 Technics 1200MK2/MK3/MK5 turntables in the past 10 years. I am also considered THE 1200s MASTER. So, I am not sure what could be causing this noise, other than some foreign matter. If your in the NY metro area, bring it on by, and I'll take a look at it, or give us a call, and I'll try and refer someone locally for you:
http://www.tweakrepair.com
- J
Posted on Jan 19, 2008
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
Posted on May 21, 2008
SOURCE: How to remove a Technics sl- db20 platter
pull
Posted on Jul 28, 2008
gokomets
  • 120 Answers
SOURCE: TECHNICS SL 1910 TURNTABLE SERVICE
The grease and lube in the mechanism will
need cleaned out and replaced due to the
"age" of table! The "lifter" may be bound
up due to grease drying out...
Posted on Apr 17, 2010
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    I recently took my turntable out of the box after being in there for years because someone wanted to buy it, but it dose not work.
    If the turntable is a belt drive, most likely the belt has probably disintegrated due to ozone contamination over time and must be replaced if this is the case. Once you have the platter off you can see the spindle that drives the platter to see if it is moving.
    Nov 22, 2014 | Audio Players & Recorders
    Technics sl 1200 dragging
    almost often a wrong set table/arm weight and a dirty needle. . i gues the last. Cleanen record
    May 13, 2014 | Technics SL-1200 Turntable
    2 BRASS PART FELL OFF UNDER TURN TABLE WHEEL WHEN MOVEING
    hehe, does it still spin. I think not, it's just a spindle just like on a technics a very stuck ballbearing, and the cheap rega and projects are nice, but for your wallet, speninding a 1000 dollars for a decent engine platter tone arm is cheaper the the upgrade stuff.
    Mar 18, 2014 | Project Audio Players & Recorders
    The turn table on my record player wont spin I can hear that it's on put wont spin.please somebody help
    Your turntable belt is off. Remove the c-clip holding the platter to the center spindle. Remove the platter and turn it bottom side up, place the rubber belt around the platter and fix it to the little post sticking up on the outer-edge surface. The little post holds the belt to the platter while you turn the platter over and put it on so that the post points right over the motor pulley. Turn the platter by hand either clockwise or counter-CW and the belt will pop off of the post and land on the motor pulley. One drop of oil on the center spindle for lube and fasten the e-clip back on. Of courseicon1.png, the tone arm might not be actuating the power switch, you can address that with the platter off as well. Good Luck.
    Oct 29, 2013 | Crosley CR249TA Turntable
    The turntable won't spin
    Your turntable belt is off. Remove the c-clip holding the platter to the center spindle. Remove the platter and turn it bottom side up, place the rubber belt around the platter and fix it to the little post sticking up on the outer-edge surface. The little post holds the belt to the platter while you turn the platter over and put it on so that the post points right over the motor pulley. Turn the platter by hand either clockwise or counter-CW and the belt will pop off of the post and land on the motor pulley. One drop of oil on the center spindle for lube and fasten the e-clip back on. Of course, the tone arm might not be actuating the power switch, you can address that with the platter off as well. Good Luck.
    Apr 10, 2010 | Crosley CR248 Turntable
    Ion turntable
    1) Remove the platter - just lift up
    2) Underneath the platter, you'll see a small lip section
    3) Wrap the belt around this lip
    4) Put platter back on turntable
    5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
    6) Pinch the belt around the motor shaft.
    7) That's it.
    - OPTiC
    MasterTech
    Digital Analog Therapy
    Turntable Parts : Turntable Repairs
    May 09, 2009 | Technics SL-1200MK2 Turntable
    Belt is off my audio-technica turntable at-pl50
    WASH YOUR HANDS FIRST! Any oils on the drive belt may cause slippage.
    This is from the manual:
    A) Remove the record mat from the turntable platter
    (Fig. 10a). Through an opening in the
    turntable platter, visually inspect to see if the drive belt
    is around the motor pulley (Fig. 10b).
    B) If the drive belt is not around the motor pulley: Lift
    and remove the turntable. Place a thumb into each of
    the left and right openings on the turntable platter; and,
    using the fingers to press down on the turntable housing’s
    surface, pull the platter straight up (Fig. 10c).
    Avoid pressing on the tone arm.
    C) With the turntable platter bottom side up, place the
    belt along the outside wall of the turntable platter's
    drive rim, making certain that the belt is smooth and
    flat all the way around (Fig. 10d).
    D) Put the turntable back on the center spindle, make
    certain it is fully seated, and align one of its openings
    over the motor pulley position.
    E) Through the opening, carefully hook the turntable
    belt with a finger or with the original red ribbon (never
    use a sharp object) and pull the belt over the motor
    pulley (Fig. 10e). Make certain the belt is not twisted
    between the pulley and the platter’s drive rim.
    F) Put the record mat back on the platter.
    G) While holding the tone arm in its rest position,
    slowly turn the platter by hand clockwise at least 10
    rotations to clear the mechanism’s automatic cycle.
    Apr 24, 2009 | Audio Technica AT-PL50 Turntable
    JVC - problem. The turntable does not move,
    Most modern day turntables are semi-automatic. You move the tonearm from the rest post
    over to the record and the platter will start turning. There is a small microswitch inside
    either below the arm base or near. There should be a flat bar connected to the base of the arm
    and this will actuate the microswitch. The switch is wired in series to the rotation motor.
    Solution: 1. Obviously verify the belt is on. Take off the rubber mat and rotate the platter.
    The rotation motor is on the left and it has a small brass spindle. The belt should
    be visable through the holes in the platter. If not pull the platter gently up, there will
    be some resistance. The belt wraps around a smaller inner ring on the underside
    of the platter and the rotation motor spindle. If it is degraded it will be stuck to the
    platter or fall apart. Generally there 3 common sizes. ( 21.4 / 23.6 / 25 inch) they
    readily available on E-Bay, search term "turntable belt".
    2. Obviously check power.
    3. Check the microswitch, it should "click", verify with ohm meter.
    4. Some turntables have a "cut" or stop function. The arm must return first to rest before
    starting again, again the microswitch is the trigger.
    Apr 07, 2009 | JVC AL A158BK Turntable
    Turntable wont spin
    If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
    The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
    Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
    Mar 10, 2009 | Technics SL-BD22 Turntable
    Technics SL-BD22 Turntable Logo
    143 people viewed this question
    Top Technics Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Ben Armstrong
    Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
