Question about Fellowes Office Suites; Adjustable Foot Rest
How to assemble fellows office suite adjustable footrest
How to assemble or change the height
What are the safety precautions I should consider when buying a balance bike?
  1. Seat height.
  2. Size.
  3. Tires.
  4. Weight.
  5. Brakes.
  6. Turning limiters.
  7. Footrests.
  8. Frame materials.
  9. Grips.
Jul 18, 2016 | Strider ST-3 No Pedal Balance Bike Cobra
Replacement gear required
There is a YouTube video on this.
Dis assembly and Repair of a Fellowes paper shredder - YouTube
www.youtube.com/
My fellowes paper shredder stripped a gear. Here I open it up and fix it with out needing to buy replacement parts.
Jan 29, 2014 | Fellowes P50CM Shredder
What important features should I look for when buying an office chair?
When pickingout an office chair, make sure it is comfortable for you! Make sure you canadjust the height and the back rest of the chair.
Jul 30, 2012 | Furniture
What is a good height for an office chair?
office chairs range from 14.5 inches all the way up to 23inches. A good height is around 19inches. Usually chairs have a lever thatallows you to raise and lower the height as you wish.
May 29, 2012 | Furniture
Does the FW19DB come fully assembled
Yes, it does come fully assembled. You will need to take the footrests out of the box and adjust them for length. Hope this helps.
Feb 21, 2011 | Drive Medical FW19DB Fly Weight Deluxe...
Plastic GEAR 5403 07-1 B1
Here is a link where you can find a replacement: http://www.sportslinkup.com/shop/0-Fellowes-gear-1.html (Part Number 205993 OEM Fellowes Shredder Gear Kit for Model P-55C). They have the whole gear assembly.
I need the same for my P-57Cs shredder (broken stage 2 gear 540307-1. Hope it helps, good luck!
Dec 04, 2010 | Fellowes Powershred P-55C Shredder
Part #540307-1 broken
Here is a link you can get the whole gear assembly for $30: www.sportslinkup.com/shop/0-Fellowes-gear-1.html (P-55C Gear Kit for Fellowes Shredders part #205993).
I need the same for my Fellowes P-57Cs shredder, same broken gear 540307-1
Sep 26, 2010 | Fellowes Powershred P-55C Shredder
I have a 2008 Triumph Sprint ST 1050. How do you adjust the foot gear change selector ?
There are 2 nuts on the bar from footrest to gear-change, 1 has a right-hand thread & the other has a left-hand thread.
Undo them both then turn the bar to alter its length thereby raising & lowering the gear-change height
Ride safe
Bike-Doc
Please mark this as very helpful (if it has been!!)
May 03, 2010 | 2008 Triumph Sprint ST
Fellowes PS60 CC shredder jamming
You have guides or cutter assembly out of alignment. Take it apart and double check before reassembling.
Jun 09, 2009 | Office Equipment & Supplies
Fellowes Office Suites; Adjustable Foot Rest Logo
Top Fellowes Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Fellowes Furniture Expert? Answer questions, earn points and help others
