Question about Infinity PS28 Subwoofer
Bose ps28 popping sound - Infinity PS28 Subwoofer
I want to connect my Bose ps28 iii to another reciever. How and what do I need to make this possible. If I run a av left right to the unit will the reciever turn the unit (bose woofer) on.
The media center plug is wired to carry your left/right signal for front and rear along with reference and turn on voltage. Here's a link to the media center cable pinout images. If you have the connector you can pigtail in your high level inputs (speaker out from the amp you want to use to the corresponding pins. However, I can't guarantee this will work. Bose makes these cables proprietary for a reason... to make money. If hillrods like you and I can easily hack their stuff then they wouldn't be able to overcharge for their goodies. Here's the pinout link anyway. Good luck! http://www.google.com/patents/EP1605637A2?cl=en
Mar 01, 2016 | Bose Audio Players & Recorders
Can I connect a Bose lifestyles PS28 woofer to a PC without the Bose Control or brains? How?
You probably can if you're patient. Here's a link to the media connector pinout. You'll have to cut a 3.5mm cable and tap into the left/right audio signals (Z1 or Z2). I'm not sure if the sub will stay on without the 10v on signal or not. That will be another problem to solve once you've tested the 3.5mm connection. Use the schematics provided in the patent link to make your connections. http://www.google.com/patents/EP1605637A2?cl=en
Feb 22, 2016 | Bose Audio Players & Recorders
How do I test the Bose ps28 3 sub woofer without any other bose components?
Thats a toughie because that system is well..a system. They build those so that each component runs through that main circuit board there and then thru the outs on the sub--I would look for a used player that you can hook it up to or pass on it.
Jan 24, 2015 | Bose Lifestyle Ps28 Iii Subwoofer Dual...
Need to replace pigtail fuse
This may not be a fuse. Bose uses devices like this as "speaker protection". If this device is wired to the woofer, that is exactly what it is. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 01, 2013 | Bose Lifestyle Ps28 Iii Subwoofer Dual...
My bose ps28 is making a rattling noise whenever bass is involved. How do i fix it?
You have lost the sponge roll surround of your subwoofer ( suspension ). Its known as foam rot.
Either you can buy new woofer drivers for the subwoofer or repair the surround alone. Kits are available. But you will need some technical skill.Check out this link.
http://popular.ebay.com/consumer-electronics/bose-speaker/bose-speaker-repair.htm
Mar 10, 2011 | Bose Lifestyle 28 System
Car speakers pop when on/off new stereo preamp out to Bose amp
Hi mate
this maybe caused by a positive and negitive wire touching somewere down the line!
just follow up your wires and check
Feb 16, 2009 | Bose Car Audio & Video
Bose wave radio wont turn on
I have one that is doing the same thing. Will your radio make a POP sound when you unplug it? I was told by Bose Tech it is 15 yrs old and they will not work on it. He told me that if it makes a POP sound that it is not the fuse or power supply???
May 04, 2008 | Bose Wave Radio
No power up
Considering that power is present, popping sound is caused by a faulty Q401, 5V supply for display.
Good Luck.
Dec 22, 2007 | Bose Wave Radio
Infinity PS28 Subwoofer Logo
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Matthew Spark
Matthew Spark
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
