Need to see a diagram on wireing fore elect starter
I need to see a diagram because, someone else took the starter apart and I am not sure how the wiring goes back together, on the starter and the new key switch
-the wires are not correctly re-installed for the starter.
- u may need wiring diagram
Did you take pictures before you took it apart, or did you tag wires before unconnecting them.
when looking at it from the front the most left is from the battery, now going right from there the little pin is from ignition, basically to flip this giant switch on. next little pin goes to your fuel shut off relay, it will turn on that relay to send power to your pump while cranking, next is the large out. far right. that goes to your starter.
I dont have a diagram here at home but first check if at the starter, the wires on the big stud are somehow touching the wire for the small bolt. is voltage from the large bolt, goes to the little bolt, that energizes the starter.
you need to source either the repair manual for them or just the ignition wiring diagram and wire colour legend for the 1980 and 1985 alfa spider to see if wire colours are different
search online
at the minimum there should be two power wires in with start and accessories an earth not sure if a starter relay was used in the 85
You can find everything you need and diagrams at http://www3.sears.com/. Just type in the model #. There is no repair manual that I know of. If you need help solving a problem once you have seen the wiring diagram let me know.
exact model
