Question about Canon i250 InkJet Printer
I have exact same problem.
Printer works as though nothing is wrong, but paper comes out blank
  • figgyp Jun 19, 2009
    Thanks have tried that. Even made sure there was ink in the cartridges too and ended having multicoloured hands!!! Think i'll just buy a new printer, probs cost more to fix lol
    Sergeant:
    Champion:
  • 310 Answers
I would suggest you to clean the catridges once and try again. that could help
Thanks
Ranjit
Posted on Jun 18, 2009
Blank paper coming out
Could paper be upside down? The rolls may be wound wrong. Thermal paper only is sensitive one side. Rolls might be defective.
Apr 26, 2010 | Sony UP DR100 Thermal Photo Printer
Hi. Printer isn't working, paper comes out blank.
Most likely the printhead is clogged. Another possibility is that the cleaning station does not work. 3 ways the printhead can clog,
1. Using Generic Ink
2. Not using the printer for a long time
3. Print a large print job after the ink indicator says the inks are running low.
You are better off replacing the unit than trying to get the printhead unclogged. Cost is usually around $40 and is only a 65% chance it willwork.
thanks
Dec 17, 2009 | Epson CX4600 Stylus Color All-In-One...
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Printer sounds as if it is printing, paper runs through,
Have you tried to clean the nozzles?
Did you print a test page after installing the new cartriddge?
Go there http://www.lexmark.com/publications/pdfs/z33/enuserlx.pdf
Sep 26, 2009 | Lexmark Color JetPrinter Z23 InkJet
Replaced ink, nothing prints not even tests
there are two main areas of concern: A waste sponge2c905eb.jpg located just under the printhead, and which helps to park the printhead when you turn the power off, and the actual printhead itself. There are also two ribbon connectors that attach to the printhead assembly--and if one of them is not fully plugged in the exact symptoms you describe will occure.
To reach the waste sponge require the dis assembly of the upper half of the printer. I can knock it out is about 5 minutes now! I have used about 50 Q tips to soak up the ink, and manually clan the long rectangular sponge as well.
It you want I can send you pictures of my printer all torn down.
Sep 04, 2009 | Epson PictureMate (C11C556001) InkJet...
Lexmark Z715 will not print but computer says it is printing
The Z715 needs a #50 black ink cartridge and a working color cartridge to print. To check if there ios ink coming out of your black or color cartridge touch the bottom of it to a paper towel and if you see a solid black blob or 3 blobs of Yellow, blue and red for the color then your problem is else where. If U are printing stuff from the internet sometimes the printer will try to use the color cartridge to print this so even though the black is working it comes out blank if the color is dry
Jan 16, 2018 | Lexmark X4650 InkJet Printer
HPF300 will not copy paper comes out blank when printing from computer and also blank when photocopying
My printer shows is out pf paper and is not.. did everything I could do and even though the paper is still there the printer doesn't print and keeps showing its status as is out of paper.
Could you help, please.
Best wishes
Oivia
Dec 01, 2008 | HP Office Equipment & Supplies
Paper goes through the printer as though printing but paper comes out blank
Just make sure the cartridges are not running out of ink. Try with different carts, It should work fine.
Apr 20, 2008 | Office Equipment & Supplies
Paper comes out with nothing on it
On the new cartridge, did you remember to remove the plastic seal from the toner? Do you get blank sheets only when you print or when you make copies too? Were you careful when clearing the paper jam or could you have accidentally damaged the printer?
Jan 07, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Canon i250 InkJet Printer Logo
133 people viewed this question
old marine
old marine
