Question about NCR A794 thermal printer usb
Mac compatible driver NCR 794 - NCR A794 thermal printer usb
Hi Dear Can use xerox DC12 with MAC OS without
There are some Mac OS drivers.I think your printer is not compatible with Mac.
The level of functionality and compatibility with the new Mac OS X 10.6 drivers are identified in the following document.
> For a list of Xerox equipment compatible with Mac OS X 10.6, click here.
DocuColor 12 Copier/Printer
Dec 14, 2010 | Xerox DocuColor 12 Printer
Is a Lexmark 3100 series printer mac compatable?
Yes ,Lexmark 3100 series printer is mac compatible .
For driver for mac you can download from the link below .
MAC driver
Hope this helps .
Mar 16, 2010 | Lexmark P3150 All-In-One InkJet Printer
I NEED TO DOWNLOAD THE DRIVERS FOR NCR 7167 . ANY IDEA ?
Try the following page. I do not know what this device does so I could not explore any further, but you will:
http://www5.ncr.com/support/support_drivers_patches.asp?Class=External\display
good luck!
Oct 30, 2009 | NCR 7167 Thermal Printer
Mac-Compatible Impact Printer???
Okidata works pretty good for 4 part forms. I've worked on dot matrix printers in the past and found that a lot of them jam with that big of a form and eventually burn the motor out a lot faster. Not a problem to handle on an Okidata.
I have yet to find a USB interface for one so that might be a challenge. Apple used to use a round serial interface. You might be able to find a workaround for that using a USB hub. I have a Belkin one at home that carries an Apple serial interface.
Another idea that could work is to use a parallel based print server with a eternet port on it. Then you can run it on a TCP/IP. The only time you need to use a browser is for administration setup on the print server by typing in the TCP/IP address into the browser.
Safari can work in place of Firefox. Make sure the printer server has Mac drivers for it.
Oct 30, 2008 | Office Equipment & Supplies
Need driver for lexmark z640 compatible with MAC OS X 10.4.10
go to www.lexmark.com click on drivers and downloads then click on OS compatibility lists. Click on MAC OS X and then click on home or small office/home office. This will take you to a complete list of compatible drivers for the MAC OS X for all of lexmarks printers. If it does not appear then there are no MAC OS drivers. Which I looked at for you and they do not have any. But you will see a list for the printers that they do have them for.
Sep 25, 2007 | Lexmark Z640 InkJet Printer
NCR A794 thermal printer usb Logo
21 people viewed this question
Top NCR Office Equipment & Supplies Experts
k24674
Are you a NCR Office Equipment and Supply Expert? Answer questions, earn points and help others
