Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Picture is out of focus, fuzzy
Blue convergence cannot be fully ajusted but the red and green can be
  • 5 more comments
  • lindacompton Jun 19, 2009
    will this repair the picture going in and out of focus
    Two last questions. You specified kit #2, and the site specifies kit #1 for my tv PT-47WX49E. I see there is no difference except for what the resistors replace. You also state that the kit comes with step by step instructions. Are they provided online along with support when the parts kit is ordered? Looks like all this takes is a little soldering. Thanks for they help.
  • lindacompton Jun 29, 2009
    I repalaced the ICs and the resistors as you advised but this did not solve my problem. It did nothing at all. Picture is still blurry.
    My brother inlaw works at an electronics place and they solder alot like this and they did this. The blue convergence is still off and green horizontal is off.have tried ajusting the picture and the color and tint and all of the other picture ajustments are very hard to ajust. Blue is the worst.
  • lindacompton Jun 30, 2009
    They also tested the resistors and said they were ok but did replace with the new anyway. Old ICs were STK392-110T and the new ones STK392-110. Are they the same?
    Do you have any more suggestions?
    Lets see if this helps you. Lost picture totaly. Have blue,red ,yellow wavy lines on screen.
  • Panasonic Master
  • 8,617 Answers
Replace the two ICs. You can get the convergence repair kit at this link which contains the parts and step by step instructions with pictures.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Posted on Jun 18, 2009
  • 1 more comment
  • Sonny Berry
    Sonny Berry Jun 19, 2009
    Yes it should take care of the issue as the ICs when getting ready to fail will have an intermittant convergence issue such as youre describing
  • Sonny Berry
    Yes kit 1 is for youre model . I was going by the original post was under the 47WX53 which is type 2. Yes they send the instructions and then offer free online tech support if you need additional help
  • Sonny Berry
    Sonny Berry Jun 29, 2009
    Have you double checked the solder connections especially on the two convergence Ics? As its easy to get a solder bridge or one of the pin pads can lift from the board when removing the old Ics which can cause a brace in the circuit trace right at the IC pin pad.
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Convergence adjustment aligns red and blue picture tubes to align with fixed green tube. Green image appears to skewed (possibly out of focus) in one direction making it impossible to get red and blue...
Ur tv convergence are dead.U know how to solders?Must replaced the 2 STK convergence ICS,some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 04, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Just the blue on my rca projection tv is blurred. on the auto convergeance it says it cant read the sensor. on manual the cross hairs for the blue are oversized and blurred. i tryed tuning in the focus but...
Have you try adjusting your focus/screen drive controls to Tube R/G/B you have a focus/screen drive control block to adjust each Tube 3 controls ontop 3under them top ones are for Focus bottom is for screen drive.Red/Green/Blue Tubes.You might need to replace convergence IC, what is your Model number printed on back of TV?
Mar 24, 2010 | Televison & Video
Red, blue and green lines, picture is red and fuzzy
Ur convergence is dead.Know how to solders?Buy a convergence kit.Replaced parts.These websites.Tv repair World.com,Tv repair kits.
Dec 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture fuzzy and brighter in center. convergence good on red but blue and green only show in center crosses. green and blue glow around figures.
Ur convergence is dead,must be placed.U know how to solders?Tries these wesites for convergence kit.Tv repair World.com,Tv Repair Kits.
Oct 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
How to fix fuzzy pic & red,blue,green lines on your screen?
Typically this is due to a convergence chip failure. This repair can be done pretty easy with the proper instruction. Have a look at this video to help determine if you truly have a convergence problem.
Jan 26, 2009 | Toshiba 57H82 57" Rear Projection...
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Sony rear projection convergence
This is a convergence problem that is either bad connections on the convergence ICs or defective ICs. IF you can solder and feel comfortable working inside the set, you can fiox this yourself. Let me know if you wish to attempt the repair and I'll post more details and instructions.
Dan
Nov 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Magic focus
you need to replace the convergence Ics thats why youre unable to align the blue. If youd like me to post a link where you can get replacement ICs as well as free tech support and instructions let me know and I will post the link.
Apr 08, 2008 | Hitachi 51F500 51" Rear Projection...
Fuzzy Blue...?
these set are bad about the blue tube messing up.. what happens is the convergence board witch generates alot of heat cooks the blue glycol.... basically growing algea in the blue tube... it is possible to remove the tube.. and remove glycol and clean the tube then replace and adjust..i have done a few here at the shop
Mar 14, 2008 | Akai PT4298HD Rear Projection Television
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
212 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
