Question about Candy Ovens
Oven not heating but grill still working
Power to oven but it is not getting hot but the grill and the fan are still working
  • 50 Answers
Call an electrician and ask them to check your 'Bake' elements.
If the elements are working, then check the oven function selector switch to make sure all of the contacts are working.
Posted on Nov 24, 2015
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    barkencoa
    • 3463 Answers
    SOURCE: fan oven wont heat up
    If fan is workintg, but no heat, then replace oven element.
    If no heat or fan, then make sure timer is set on manual and not on auto
    Please rate my solution.
    Thanks.
    Posted on Jul 01, 2009
    barkencoa
    • 3463 Answers
    SOURCE: Candy F254/3X single fan oven, grill works, oven doesn't.
    If fan is working o/k, then you need to fit a new oven element
    Please`rate my solution.
    Thanks.
    Posted on Aug 24, 2009
    Testimonial: "Possibly looking for a bit more info. My manual talks about top and bottom elements. I take it the grill is the top element."
    • 12 Answers
    SOURCE: indesit fde20 main oven wont heat up
    sounds like the circular element at the back of oven has blown.
    Posted on Oct 24, 2009
    barkencoa
    • 3463 Answers
    SOURCE: oven not heating up [fan works]
    It wilbe a faulty oven element, you will need ti fit a new one.
    It is located at the rear of the oven, behind a removeable cover.
    Thankyou.
    Posted on Feb 11, 2010
    Heating elements in fan oven not working
    This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
    Here are the 3 main faults to look for in your oven or cooker that is not heating
    • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
    • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
    Nov 26, 2011 | Smeg Ovens
    Hi my zbf260w built in fan assisted oven is not getting heat in the oven department.The fan and grill are both fine but not the oven,
    If the fan is working o/k, then y ou need to replace the oven element, located at the rear of the oven compartment behind removeable cover.
    Sep 26, 2010 | Zanussi Ovens
    Wont get hot grill works think the element has
    If it is a fan assisted oven, then it is probably the oven element that has failed.
    This is usually located at the rear of the inner oven compartment behind a removeable panel
    May 04, 2010 | Ovens
    Fan not heating
    1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
    2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped like us on facebook please
    How to Video Tutorials on Domestic Appliances
    Mar 12, 2010 | Zanussi ZBQ665 Electric Single Oven
    Smeg oven
    1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
    Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
    Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Nov 12, 2008 | AEG D2100-4 Electric Double Oven
    Ovens Logo
    50 people viewed this question
    Top Candy Ovens Experts
    ashburton
    ray gallant
    Gaark
    Are you a Candy Oven Expert? Answer questions, earn points and help others
