Question about Kitchen Ranges
Frigidaire 316246600 How to lite pilot
2 Suggested Answers
  • 7 Answers
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
Posted on Jan 30, 2009
Is there a pilot lite I need to light for my stove ffgf3011lw
Some stoves have pilot lights, some have an electronic igniters. If you hear a click, click, click when you turn on the gas, you have igniters.
Dec 06, 2014 | Frigidaire 30" Freestanding Gas Range -...
I just got a new tank of gas, is there a pilot light that i need to light
If you turn the dial to lite (stove top), and you hear a clicking... it is a piezo ignition system (no pilot).
Nov 02, 2013 | Frigidaire FGF326AS Gas Kitchen Range
Not light
check to make sure that the poilet lite flame is touching the tip or top of the thermocouple.
the pilot lite needs to heat up the thermocouple so that the thermocouple opens the gas to the main gas log. a cold thermocouple shuts off the gas to the main gas log or gas burner and a hot thermocouple opens the gas to the main burner.
the pilot lite flame must be touching the thermocouple to heat it up.
pilot lite orface needs to be clear to let the pilot flame gas through with enough pressure so that the little flame can reach & touch the thermocouple. Pilot lite gas feed tube must be clear to let gas through. Use compressed air or a fine sewing needle, or even carb cleaner to clear out orface hole and gas feed line to pilot lite.
important!! WARNING:
if you use carb cleaner,make sure all the carb cleaner is dry,soaked up with paper towell or kleanex tissue and blowed out with compressed air , because carb cleaner can burn just like gasoline; so any carb cleaner must be compleatly gone before you attempt to lite the pilot lite.
May 20, 2013 | Lite On Laars Lite 2 Heaters: 250,000BTU...
It runs out of fuel
sound like pilot lite is not getting thermocouple hot.
check that pilot lite flame is extending out to and touching thermocouple. If not, clean out pilot lite orface and pilot lite gas feed pipe all the way back to the main gas valve if necessary.
If pilot lite flame is touching thermocouple, then replace thermocouple
Jan 22, 2013 | Mr. Heater Big Buddy Heater
How do I lift the stove top to turn off pilot model # FGF366DCB?
there isn't a pilot in it,it has an electronic spark module in it.what problem are you having?when you turn it to lite it you'll hear a clicking sound,that's the sparking that lites the gas just like you're gas grill.if you want to remove the top you have to remove the two phillips screws out of each burner head,sometimes they don't come out and you have to drill them out,if the burner isn't shutting off the gas valve could be broke or the knob could be broke,if it's clicking just unplug it and you can lite the top burners with a match or bbq clicker to lite them until you get it fixed depending on what problem you are having.if the gas won't shut off by turning the knob you'll have to shut down the gas at the valve that feeds the stove.but like i said if you want to lift the top you have to remove all the screws in the burner heads.hope this helps you out.http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Range-Parts/Model-FGF366DCB/1428/0124002?pathTaken=&prst=0&shdMod=FGF366DCB go to this site and you can look up your machine.
Sep 03, 2011 | Frigidaire Ovens
WHERE IS MY PILOT ON MY FRIGIDAIRE FGF368GM
Hello, There is no pilot..It uses ignitors to light. number 19 in this picture is the oven ignitor http://lookup.bellparts.com/diagramenlarge/frigidaire/47877/00000358
If when you turn on the oven it doesnt glow bright orange chances are it failed and needs to be replaced. The top is electronic ignition. If this helps please rate me..Thanks
Jun 08, 2011 | Frigidaire FGF368GM Kitchen Range
Oven pilot light is lite .but oven does not ignite.model# mpf300pbwc
Hello, The thermocouple may have buildup on it. Try to chean the thermocouple which is the small rod going through the oven pilot. You will have to blowout the pilot and clean the thermo with fine frit sandpaper or some guys use a dollar bill. Just shine it up light the pilot and see if it lights.
Jun 06, 2011 | Frigidaire Ovens
Laars lite 2
you will need to take pilot assembly out and replace thermal couple also check flue
May 04, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Kitchen Ranges Logo
21 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
