Question about Spinball Wizard Baseball Pitching Machine
Will not hold pitching position
Will not stay tight in pitching position vibrates loose
Plastic agitator on bottom of drum keeps coming loose and doesn't stay in place ?
Pop off cap on agitator to expose drive shaft. See that the nut is tight orvthat it did not vibrate loose
Jan 24, 2016 | Washing Machines
How to tighten blade
if the blade is unbalanced it will not stay tight and should be replaced then with a block of wood to hold the blade from turning tighten the replacement blade
Jun 10, 2012 | Black & Decker 19" Electric Lawnhog...
Trunk pop open when driving
close hood and lift up on hood to see if it stays closed.
if not, check inside car to see if latch(that you pull) is in the correct position. you can tell when hood is closed that there will be some tension on latch.
check under hood, where hood closes on latch of hood, is tight and secure(no loose bolts)
also check cable if broken.
only those things can cause hood to pop open.
if all visual inspections check out and still continues to open while driving then the latch (the mechanism that hold the hood down) is bad. vibrating while driving will cause it to open.
May 12, 2011 | Volkswagen Jetta Cars & Trucks
The chain will not stay tight. After about i minute of cutting the chain gets loose and jumps off of the bar. I tighten everything really tight after adjusting the tension. It runs and cuts fine until...
On the aduster screw where you tighten blade ... is there an extra nut? I think you need to screw that nut tight so the adjuster screw cannot rotate from vibration.
Oct 08, 2010 | Homelite Garden
Rheem condensing unit fan motor failure?................3rd motor was replaced by contractor on 3 year old unit. Unit starts vibrating very badly and will also start vibrating when blocking airflow. All...
Could be the fan blade is the issue for vibration. Perhaps the blade was bent or somewhat damaged during failures or during the fan motor replacement process.
Might try replacing the blade. Be sure to install the correct blade. Pitch, number of blades as was on the original unit. If blade was replaced previously, the new blade may be pitched or sized incorrectly.
Sep 02, 2010 | Heating & Cooling
A loud vibrating sound
Bad compressor, if the compressor is going bad or the bolts that hold the compressor in place are loose. Check to make sure the bolts are tight. If not check the compressor with your hand and see how much it vibrates.
Jan 02, 2010 | Kenmore 53642 / 53644 Side by Side...
VIBRATION-THRU SEAT & FOOT RESTS AFTER ENGAGING BLADE
get down and gun your fingers in the slot that the belt rides in, soulds like you may have a small rock or piece of wood lodged in the v part of one of the pulleys. I bet thats it Jim
Dec 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Top freezer door does not close tight
Sounds like the top hinge is loose. If the hinge has a cover, remove it then hold the door in the correct position and tighen the hinge screws.
Aug 31, 2009 | GE GTS22KBP Top Freezer Refrigerator
High pitched noise coming from set.
hi there high pitched noise form the set indicates that one of the coils inside the set are lose this happens with age and heat the coils are made of copper and are tightly glued or soldered together and can be as small as a bit of hair of as big as a pen tip the problem is that the coil is now vibrating which is causing the high pitch sound and sound be quite easy to identify with a good ear!
sometimes these can be sorted with a quick bit of solder to hold it in place on the main bord of where the coil is, but some times there is no cure due to very small braiding of the copper wire any attempt to solder may cause damage and breakage,
You may be able to replace the coil with another one from a good components store with the same value best thing is to take out the noisy coil and take it down to be replaced
the reason it appears worse when first turn one is that the coil is cold and vibrates alot more just like when the set is warm the coil expands like most metals do which stops it vibrating so much
i hope this helps a little good luck
Feb 05, 2009 | GE Televison & Video
The lap top computer screen is loose
Those screens tend to lose their tightness as time goes on from all the opening and closing. Regrettably, there isn't much to be done with them except replacement of the part. You can jury rig it but that's about it. I,too, had a zv5000 and experienced the same thing.
Please don't hold my bad news against me when you rate my answer! ;-)
Jan 11, 2009 | Computers & Internet
Spinball Wizard Baseball Pitching Machine Logo
145 people viewed this question
Top Spinball Baseball & Softball Experts
Nate Brez-Men
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Spinball Baseball and Softball Expert? Answer questions, earn points and help others
