Question about Acroprint Time Q-Plus Biometric Attendance System - 01-0250-000
Clock terminal not responding
At the computer i am getting a clock terminal not responding,what can i do to fix it?
Elantra 2001 clock not working
This is a common problem with these clocks where the set buttons stop responding. The only fix is to replace the clock unless you want to do some detailed soldering to replace the micro-switches.
Oct 12, 2014 | Hyundai Elantra Cars & Trucks
Controller will not respond to clock nor the manual setting
Remove batteries wait 10 min Clean battery terminals with metho
then try again sounds like corrission on battery terminals
Apr 03, 2014 | Garden
W58814 RADIO
a quick tip for you. disconnect the battery negative terminal just before 12:00 O'clock noon. Then right at noon reconnect the cable. Most radio's default set to 12:00 noon. Now you clock is set.
Mar 11, 2014 | 2001 Toyota Prius
I have forgot my BIOS password
The only way to reset the bios password is to reset the bios itself. Depending on the make/model of your computer, there might be a little button on the back of the unit which you push with a paperclip. Turn the computer on and while the BIOS is booting, press the Pause'Break button on your keyboard. That should stop the BIOS boot...Or attempt to get into it so that it waits at the bios password screen, then press the button. It should reset the computer, then when it comes back up (you might need to hit it twice, then turn the power on), it will say something about the clock being wrong, enter the setup to fix it. Go ahead and enter the setup, reset the clock, then (if you need to) reset the password to something you'll remember.
If there's no button, then you'll have to reset the bios using a jumper on the motherboard. The jumper's location varies based on the make/model of your computer. If you respond with said make/model, I should be able to look up how to do it, and I can respond back with the specific instructions.
Tj
Aug 08, 2011 | Computers & Internet
Application spaprv is not responding to vmac
I think you have a flashing TAMPER MESSAGE in your machine or better yet you have a corrupted program that needs to be reloaded with the help of your credit card processor. If you still need help you call us in this number (775)358-2922 and ask for Randy. Thanks.
Aug 06, 2011 | VeriFone VX 610 Credit Card Terminal...
Model T104P wiring instructions for 110volt motor
T104 timer is for 240 Volt circuits. It has internal 240V clock motor. Clock terminals and timer terminals are connected, so there is no way this timer can control 110V circuit.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
T101 timer is for 110V circuit.
T101 has 110V clock motor
Both white neutral wires = terminal A.
Black hot wire from breaker box = terminal 1
Black wire to load = terminal 2.
Grounds = green screw
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
T103 timer is for 110V circuit
T103 has 110V clock motor
Black hot wire from breaker box = terminal 3
Black hot wire to load = terminal 4
T1905 timer is for 110V circuit.
T1905 has 110V clock motor
Both white neutrals = Clock terminal
Black hot from breaker = COM
Black to load = NO [load comes on when timer turns on]
Sep 21, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Once T101 Timer Shuts Off will not turn back on
you have the hot and load reversed. the power source should connect to terminal 1. the wire going on to the pool pump should be hooked to terminal 2.
the clock motor is powered off terminal 1 and A is the neutral.
what u have done is hooked the power source to #2 and the load to #1, simply switch them and everything should be fine, here is a link to the wiring diagram for the timer.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t101%20-%20english.ashx
Aug 22, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
Flash cards are not responding
Take out the flash card and clean the terminals with good eraser then plug it back in and try it. Just make sure you ground your self before touching the flash card. Also make sure not to touch the terminal.
Dec 07, 2008 | Computers & Internet
Acroprint Time Q-Plus Biometric Attendance System - 01-0250-000 Logo
506 people viewed this question
Top Acroprint Computers & Internet Experts
David Payne
David Payne
Are you an Acroprint Computer and Internet Expert? Answer questions, earn points and help others
