The 'out of paper' light stays on. I add paper, press light reset button, but light remains on and printer will not try to operate
  • davepobst Jun 18, 2009
    Wil buy a new printer. Thanksl
    Top Expert:
  • Office Equip... Master
  • 81,400 Answers
This light comes on based on how many times the printer tries to load a sheet of paper, chances are the loading mechanism is defective, that is the usual cause of this problem, u will find it is cheaper to replace the printer than have it repaired, this is from personnel experience on 2 different printers.
Posted on Jun 18, 2009
Blinking green light
Here is the diag lights information from the HP 1160 service manual. It really sounds like you have worn pickup rollers in your printer. When these rollers get worn out the printer can not pickup the paper to feed it into the unit so it thinks that this is a paper jam but in fact no paper even moved. Pull the paper tray out and inspect the pickup roller. The surface should be like a fingerprint, not smooth, but with a rough texture. If it does appear smooth then they will need to be replaced. They roller can be purchased from Amazon and is end user installable. You can get one here:http://www.amazon.com/gp/offer-listing/B000MYV6E8/ref=dp_olp_new?ie=UTF8&condition=new
I hope this helps you get the printer going again.
Jun 25, 2013 | HP LaserJet 1160 Printer
Canon MP198 error E3
Issue: ERROR LED: E, 3 Solution: Remove paper jam then press Black or Color button (MP150) If paper is jammed, remove the paper jam then press <Black> or <Color> to clear the error.If paper is jammed in the auto sheet feeder or paper output slot, paper will not feed through the printer. Please follow the instructions for Clearing paper jams from the auto sheet feeder (ASF) or paper output slot.If Credit Card sized or 4" x 6" paper is set in landscape orientation, it will jam. Please follow the instructions below for Clearing credit card-sized or 4" x 6" paper jammed inside the printer.Clearing credit card-sized or 4" x 6" paper jammed inside the printer:Power the printer off.Load the same paper type as the jammed paper in the portrait orientation. Power the printer on. (The printer feeds the paper, resulting in ejecting the jammed paper.) Load paper properly in the portrait orientation to resume printing.TOP Clearing paper jams from the auto sheet feeder (ASF) or paper output slot:Power the printer off.Pull out the paper gently.If torn paper remains within the printer, open the scanning unit (printer cover) to remove it.Caution: To prevent injury or damage to the unit avoid touching inner parts.Power the printer on and confirm that the Alarm lamp is off.Note: Any jammed paper that remains within the printer may be ejected automatically.Load paper properly to resume printing. Issue: ERROR LED: E, 3 Solution: 2 Press ON/OFF switch to reset the multifunction device Reset the device when it is not functioning properly.If the device is not functioning properly or to clear memory, reset it.Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. Click here for instructions to attempt a service reset.On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Wait approximately ten seconds and then press the <ON/OFF> button again.Wait until the device has completed its cycling process before submitting another job request.Service Reset:On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Confirm the printer is not on and then unplug the power cord from the back of the printer.If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.Press the <ON/OFF> button repeatedly five times.Re-connect the power cord.Press the <ON/OFF> button to power the printer back on.Wait until the device has completed its cycling process before submitting another job request.Important:This procedure will not resolve a physical hardware issue.For example, a paper clip is wedged between the paper feed rollers or gears; or, the scanner assembly is detached from the inside housing. This procedure will not resolve all service errors or LCD related anomalies.Service errors appear as four characters (a combination of alpha and numeric codes).
Oct 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I lost my installation cd for my x2470 printer. I do not have money,is there a way to install it witout a cd
    • Step 1 Open your web browser and go to Lexmark's "Drivers and Downloads" page (see Resources section below). Locate the search box labeled "Search by Model" and enter X2470. Press return. Select your operating system from the pop-up menu. Wait for the download page to load, then click the "Download Now" button. Save the installer file to an easily accessible location.
    • Step 2 Rotate the printer so that the rear section is in view. Connect the power cord to the power cord connector located on the right. Plug the remaining end of the power cord into an electrical wall socket. Connect one end of the USB cable into the USB port located on the left. Rotate the printer back into place.
  • Step 3 Turn on your printer. Extend the paper guides and insert paper into the tray. Readjust the paper guides so that they are flush with the paper.
  • Step 4 Lift the scanner unit and wait for the print cartridge holder to move into view. Push down on the light blue lever to raise the cartridge holder lid. Install the ink cartridge into the print cartridge holder. Close the cartridge holder lid and lower the scanner unit.
  • Step 5 Connect the remaining end of the USB cable into any available USB port on your computer. If any "Add New Hardware" screens appear on your computer, click "Cancel."
  • Step 6 Open the previously saved installer file and follow the onscreen instructions.
  • Step 7 Locate the button on your Lexmark X2470 that looks like an open scanner pointing to a computer monitor. Press and hold this button for three seconds. Follow the instructions that appear on your computer. Once this is complete, your printer is ready for use.
May 23, 2011 | Lexmark X2470 All-In-One InkJet Printer
How do I get it off of Manual feed?
I am assuming that you have paper in tray 2.
Lets try to inititialize the NVRAM.
This will reset everything in the printer.
1. Turn power off
2. Turn it on. When the memory count begins, press and hold the up arrow ^ until all three control panel lights flash once and then stay on.
3. Press the down arrow
4.
Press the menu button. You should see Full NVRAM INIT in the display
5. Press the select button.
After the printer becomes ready, print. Make sure paper is in tray 2.
Oct 26, 2010 | HP LaserJet 2420 Printer
Canon Color Bubble Jet Printer i550 wiil not print - (greenlight then orange light blinks 8x - then green light) When attempting to print receive "Printer not responding" - "Paper thickness lever...
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Office Equipment & Supplies
I set up my own wireless network and now my printer will not communicate with my laptop.WIFI light flashes red. Have tried everything to reconnect. Lexmark Z2420.
I suggest you reset the Lexmark Z2420 wireless network adapter. To reset, do the following: With the printer on, press and release the power button. The printer will enter power save mode. Now, press and hold the paper feed button. While holding down the paper feed button, press and release the power button. Continue holding the paper feed button for 30 seconds. Release the paper feed button. This will reset the internal network adapter (INA). When the printer has been reset, a solid orange Wi-Fi indicator light should appear. If Wi-Fi light goes back to flashing red, you have not successfully reset the printer. Start the procedure again. Once you have a solid orange Wi-Fi light, reconfigure the printer for wireless connection. Thanks.
Jul 29, 2010 | Lexmark Z2420 Printer
Attention light blinks after jam
most of the HP printers will detect the paper jam and will provide you with help window automatically to rectify the problem. If paper gets jammed, just remove it from backside and then turn off the printer and power it on. cancel any pending printing documents. Everything have to become normal. If it not, try restarting your system too.
I hope its helpful to you
Sep 07, 2009 | HP Photosmart D5160 InkJet Printer
Keeps giving me E2 not printing a paper will com e through when
If you hear the printer trying to grab the paper (you also may see that the rollers turn) but it does not grab the paper , means the the rubber that grabs the paper are dried, and should be replaced.
If the rollers do not turn (no sound either) then there is a problem with printer's mainboard.
Meanwhile (if you need it urgently) put more pages in tray to add volume (will press the paper to the rubber).
Mar 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E 2
hi dear
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Mar 26, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP 2420dn out of paper
To perform a cold reset
1. Turn the printer off.
2. Hold down the SELECT ( ) button, and then turn the printer on. Continue holding down
the SELECT ( ) button until all three printer control-panel lights flash once and then
remain on. This might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the
UP ARROW ( ) button or the DOWN ARROW ( ) button until COLD RESET is highlighted.
4. Press the SELECT ( ) button. The printer performs a cold reset and then continues its
power-on sequence.
5. Check all I/O settings and reset any customer-set printer configuration values.
ENWW Printer resets and power-on modes 163
Mar 14, 2008 | HP LaserJet 2420 Printer
27 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
