Question about Kenmore Elite 78722 78729 Bottom Freezer French Door Refrigerator
Kenmore elite, 795.7205 bottom freezer is making a buzzing noise and isn't working
How do I access the evaporator fan motor on this model?
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
aborcass
  • 2651 Answers
SOURCE: Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Posted on Nov 17, 2008
  • 31 Answers
SOURCE: Kenmore Elite model 73503201- FRIDGE DOES NOT COOL, FREEZER WORKS
Look in the back of the freezer, there will probably be a metal panel with a plastic vent on top.
Look through the vents in the metal panel, and you should see the shiny metal fins of the evaporator. If the fins or the vents are plugged with frost, that is your problem. The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. If either one of the parts fails, the freezer will plug up with frost every few weeks. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
bobicehouse
  • 1524 Answers
SOURCE: Freezer quit working on '04 Kenmore Trio Elite 25' bottom
Can either be starting components for compressor, or Motherboard.
Posted on May 04, 2009
  • 103 Answers
SOURCE: the motor on the Kenmore refrigerator is running continuously. How do I stop it? I just cleaned out the dust from the coils underneath and replaced the kick-plate at the bottom
Hi: I've dealt with Kenmore for 30 years. Unfortunately the new model numbers don't reveal the age. I must assume it's a newer model. I'm not disputing what you said about it running all the time, but please read on. Oddly enough the new energy efficient referigators run 70 to 80% of the time. They use a smaller compressor without the big amperage start-up. The best I can describe them is that they freewheel alot. The 106......of your model number means it was built by Whirlpool. A very quite and energy efficent refrigerator. If your power bill is high get a meter from your power company, most have them. Just to double check the power consumption. Good luck Jeff
Posted on May 31, 2009
Kenmore model7957160 error code erff
ER FF is a Error Message that your Freezer Fan is not working properly, W10128551 Evaporator Fan Motor The problem could be your=> 2169142 Fan Blade has become damaged either by ice or loose fan motor mounts. Someone will need to unplug and remove the rear panel of freezer to observe just what has taken place, Thanks Sea Breeze
Feb 17, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore model # 59675522400 The fridge is
Hi and welcome to FixYa, I am Kelly. You have most likely found the problem being the evaporator fan is turning slowly. Most of the time if there is a voltage problem with and evaporator fan they just do not turn at all. I suspect that the fan bearings are dry and the armature is not turing full speed.
Sometimes you can lubricate the motor with a parrifin based oil and revive them. Most of the time on the white motors lubrication does not work as you can only lubricate one of 2 bearings due to the motor design.
Your evaporator fan motor is here: Detailed view
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-elite-Parts/Refrigerator-Parts/12002744/0046/464/Model-59675522400/0583/0161000?keySuffixId=NA&productTypeId=0161000&searchModelNumber=59675522400&subCompDesc=Evaporator%20area%20&%20rollers&brandDesc=KENMORE%20ELITE&modelDesc=KENMORE-REFRIGERATOR&blt=11
Component location view: (item 18)
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675522400/0583/0161000/M0705003/00010?blt=06&prst=&shdMod=
All other parts:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675522400/0583/0161000?pathTaken=
The Evvaporator fan motor voltage should be 120 VAC across the 2 fan motor wires.
Thanks for choosing FixYa,
Kelly
Nov 19, 2010 | Kenmore Refrigerators
I have a Kenmore elite bottom freezer model. The fan started making a funny noise.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace the blade. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged and rubbing against it. Check the rear condenser fan as well for faults. It is possible that the noise is coming from the motor itself. If that is the case, you will need to replace the affected motor.
Aug 23, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite french doors bottom freezer Model # 795.77573600. There is an message Er FF and is very noisy.
Well you got a kenmore that i believe is actually made by either Samsung, or LG, since Kenmore does not make any refrigerators, they are ALL taken from other name brands with the name kenmore put on the front. I would start by looking at your owners manual for troublshooting codes, but chances are you have a faulty evaporator fan motor, either the motor itsself is out of balance, or possibly ice is obstructing fan blade, and you'll need to find the source of that problem instead. hope this helps
www.FixMyFridge.net
Mar 08, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite error message er ff
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
Kenmore Elite Trio 596.76529500 It makes a
It is the Freezer Fan, he ice maker fan. I experienced the same conditions of a two year period. The tech allows said either unplug overnight. I as you couldn't take the noise. Oh by the way it will be getting worse!!! The solution replace the Freezer Fan motor.it cost about $78.00 plus shipping. they are located behind the freezer rear wall. They are very labor intensive to replace because the electrical leads are attached just out of reach. I have a 33" arm and I had to act like a contortionist to unplug them.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite 78722 78729 Bottom Freezer French Door Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
