Question about Euro-Pro 9130 Sewing Machine
How to change the lightbulb ? - Euro-Pro 9130 Sewing Machine
Tip
How to change lightbulb in Air Electronic SU TSP Jubilee 500 and Carinas
If you own an Elna Air Electronic and blow a lightbulb then here is the instructions to change it. The lightbulb will be a bayonet fitting 15w but maybe remove old one first to make sure you get the right length bulb at the shop.
Firstly unplug the machine. Take your mini screwdriver that came in your kit and look at the top of the machine above the needle. There is a little hole there, put the screwdriver into the hole and push down on it, this lowers the bulb holder in the head of the machine down below the casing on a slant towards the back of the sewing bed, its spring loaded so you may need a second pair of hands to do it the first time.
Hold the screwdriver down, and grasp the bulb, push it up and twist anticlockwise to undo the bayonet fitting. Push down and repeat the process to insert the new bulb, turning clockwise to insert it into the bayonet fitting. Release the screwdriver and the bulb holder will retract back into position.
If you have a Stella air electronic then it is very similar except for the location where you need to push. On the Stella look at the rear of the machine head above the bobbin cover and you will see a little slide mounted right at the end of the rear casing. Same thing but for these, put the screwdriver across the top of the slide horizontally, then push down on it to lower the bulb mounting.
That's it! Happy sewing.
on Oct 19, 2011 | Elna Sewing Machines
How do i change the light bulb
You need to consult the owner's manual. Some machine lightbulbs need to replaced by a professional technician.
Aug 24, 2015 | Sewing Machines
Change light bulb in classica 100
I have a Husqvarna Classica 100 and need to lower the lightbulb guard so as to change the bulb. I have read the manual, but still cannot figure out how to do it. Any help would be greatly appreciated.
Feb 13, 2013 | Husqvarna Sewing Machines
TYPE OF LIGHTBULB FOR JANOME SEWING MACHINE
try these sites for parts---some of these sites you may have to email
about the part
ebay
sewingpartsonline.com
sew4less.com
sewvacdoctor.com
a1sewingmachines.com
Apr 30, 2012 | Janome Sewing Machines
How do you remove the lightbulb on a Singer 185J machine?
sometimes the manuals don't cover every thing that they need to .
Apr 21, 2012 | Sewing Machines
Euro-Pro 9130 Sewing Machine Logo
26 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
