Question about Microsoft Xbox 360 Console
My xbox 360 freezes up so i cant even get to the dashboard
    Genius:
  • 1,093 Answers
This happens because the GPU and the CPU get too hot.
The soldering snaps off and once they cannot communicate you are left with the red lights of doom.
To fix it you just need to stop the motherboard flexing and you can use a good repair guide or send it back to Microsoft.
I would not suggest doing the towel trick though this heats up all the Xbox 360 and can't be good!
Posted on Aug 26, 2009
  • 767 Answers
Yes both above solutions are sound advice . Note of cation,
when and if you decide to do the x clamp mod its critical
you put a very thin film of heat sink compound on, and you
may not have to heat gun the G.P.U. , I only do this with
dead video and no power after i find power to the board but
no power up. just make sure you evenly torque the heat
sink down prior to burn in.
Posted on Jul 02, 2009
    Problem Solver:
  • 4 Answers
Also a much easier way to do what the guy above said, like with the heat gun without having to go out and buy the heat gun... is.... you open your box and take out the fans... still have the fans plugged in, but take them out and put it on top of the cpu heatsink, so that way it heats up the gpu, but not the cpu. let you're xbox sit for about 15 minutes or so while the gpu bakes and then turn it off and let it sit for another little while to cool it down. start it up again and it should work if you've done the x clamp fix and replaced the thermal paste.
Posted on Jun 19, 2009
    Sergeant:
    Champion:
  • 452 Answers
If you don't want open the box then the towel trick is the only option. (not recommended)
Recommended fix: get youself a xbox repair kit and replaced the xclamps. You can get them at GamesRepair.com
My personal favorite method: Get yourself a heatgun. You can fine them at most hardware store for like $25-30. Open the case, take out the heatsink on the GPU. Set your heatgun at 300-400 degree and blow at the GUP for like 90seconds at circular motion and two inches above the the GUP. Let it cool down and apply new thermal compound. Put the heatsink back and everything else. Test your console before putting the case back on.
Posted on Jun 18, 2009
5 Suggested Answers
  • 9 Answers
SOURCE: Im Stuck In The Xbox 360 Dashboard And i Cant Get Out Of It
first off go to your system settings then console settings go down to locale if it dosent work after that u will have to create a new email and try again i would appreciate it if you could rate this solution
Posted on Jan 11, 2009
  • 4 Answers
SOURCE: dashboard change to xbox 360 pro style
there was a update a while back this year or last that changes the whole of xbox live gaming eg parties are now availible new channels inside xbox spotlight etc nothing to worrie about
Posted on Jul 24, 2009
  • 297 Answers
SOURCE: Every time I try to
Yes the freeze ups are caused by overheating and the reason this happens is because the soldering between the 2 main chips has come loose it is very common.
You need to reconnect the soldering which is not as difficult as it sounds, you can either send it in and they will fix it for you and this will take about 4 weeks.
The other way you can do is to use a good Xbox 360 Repair guide which will show you with video how you can do this with household items.
I hope this has helped you and if you liked this solution please rate it so it can help others.
Posted on Dec 28, 2010
mikeshouse11
  • 22 Answers
SOURCE: When i click on the
This is probably an error within the Netflix file on the Xbox. Try to delete and reinstall Netflix by going to the memory and hard drive.
Posted on May 10, 2011
Why does it keep shutting down after 5 min of playing a game?
Xbox Keeps Turning Off - Xbox 360 S - iFixit
https://www.ifixit.com/Answers/View/.../Xbox+Keeps+Turning+Off
iFixitI put up with it turning off of a couple of weeks and then the power cord blew up ... The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. ... After your description, I am starting to think that your power brick is the problem. .... in i cant donothing about if i was trying to play my gta4 in keep cutting off in 1 ...
Does Your Xbox 360 Keep Freezing? ' MyGamerXP
www.mygamerxp.com/xbox/does-your-xbox-360-keep-freezing/
Sep 14, 2015 - 5. Check Your Xbox 360 Hard Drive. Not only can the cache corrupt from .... I unplugged the console when it froze instead of turning the power off. ... hi my 360 keeps on freezing on any game i play and like the screen frezzes but .... It willnot, even after 6 goes, play, it freezes, and after about 2 mins, it ejects.
My 250GB Slim keeps turning itself off every 5 - 10 minutes ...
forums.xbox.com/xbox_support/f/7/t/156970.aspx
Xbox
Jan 17, 2016 | Video Game Consoles & Games
Xbox 360 freezing on the dashboard
Check internet connection, and try downloading it to the HD
May 28, 2012 | Microsoft Xbox 360 Console
Every time I try to start up netflix on my xbox 360 the system freezes while loading netflix (at the red screen). I cant even get to the menu to pick a movie. This happens every time. The system must be...
Dec 28, 2010 | Microsoft Xbox 360 Console
My xbox 360 is starting but soon as it gets to dashboard the screen freezes?
my xbox 360 is starting but soon as it gets to dashboard the screen freezes?
Nov 19, 2010 | Microsoft Xbox 360 Console
Saints row 2 loading problem
try and save the game to your Xbox360 harddrive(HDD) and then run it off that?
Sep 26, 2009 | THQ Saints Row for Xbox 360
Ill play for about 4-5 minutes and the game will freeze up.
before you play have a fan blowing on it for ten mins. then whenever you play put the fan on low while you play. it worked for me.
Jul 11, 2009 | Microsoft Xbox 360 Console
Game freezes
Your disc could have a scratch or your Eye Reader in your XBOX is bad. Same thing for me on Oblivion i walk in an area and BOOM my disc freezes
Jun 14, 2009 | Bethesda Softworks Fallout 3 for Xbox 360
Freezes on first screen
it sounds like your chip is fried same problem i had send it to microsoft!!
good luck
Jan 20, 2009 | Microsoft Xbox 360 Console
Xbox 360 Freezing Problems
Shutting off the Xbox corrupted the Hard Drive... Have you ever got a Live System Update? You can also reset your Xbox without shutting it off using the controller. You probably have the Three Red Rings of Death... Go to this...
http://www.fix3redlights.com/?p=bfy&m=1&gclid=CKTS1MGEmpcCFRlRagodpD9H-A
Nov 29, 2008 | Microsoft Xbox 360 Console
Xbox 360
send back to MS, this will just get worse and then show ring of death.... send it back now while in warrenty.
ta alan
Jun 20, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
262 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
