Question about Refrigerators
ED5PVEXWS freezer smell - Refrigerators
How do I get rid of bad smell in the freezer part of my Zanussi fridge freezer ZBB 6286. Pilot light and fast freeze light are flashing.
first cut a potato in half and push it ion the middle of the freezer, it will absorb the airborne bacteria and reduce the smell . leave in freezer for about 2 hours then take out an throw away. next pour bicarbinate of soda into a bowl and put it into the freezer also leave overnight and smell should be gone
Mar 03, 2015 | Zanussi Refrigerators
We have an older model freezer. The door was left open and we had cleaned up the mess. Now we have a horriable smell around the exterior of the freezer. The interior does not smell. Do all freezers...
Have it clean and use a appliance cleaner that has fragrance to smell it good again.
You must eliminate the source of horrible smell.
Then apply the cleaner on rags, wipe it around the freezer exterior.
Some freezer do have pan and some don't have, so you should look for it carefully.
Good luck.
Jun 26, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
My Whirlpool Refrigerator ED5PVEXWS Not Getting Cold. We got up this morning and everything in the freezer melted. We bought it in November. it still gets power the lights are on inside. still under...
First thing I would consider is the=> W10135899 Defrost Control Board The first thing that stops is the compressor and fans most times when they go bad. You can find this board here=> ED5PVEXWS00 Control Panel Your control panel is found above the top shelf inside the fresh food compartment. Just unplug the power to refrigerator and lower the panel and where part 6 is in the photo is where the board is located. Most times when these boards burn out it creates this problem you described. Replacing that board should get you going and back to cooling normally. I will be here if you have other questions, Thanks, Sea Breeze
Apr 23, 2011 | Refrigerators
Foul fish smell emanating from the freezer
Well an old remedy is to put a box of opened arm and hammer baking soda in the freezer and fridge to keep it from having bad odors.If that doesn't work you can try some charcoal it is perfect for absorbing odor, just don't use the matchlight kind or it will smell like lighter fluid.
Apr 06, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer started emitting a chemical smell and food is thawing.
if its a sweet sickly smell then its possibly just a relay thats burnt out,should be cheap enough to replace,its the call out thats the killer.
Mar 11, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
New freezer. 15 days old. mildew smell in the
There is a curing process for the foam used to insulate these. It can give off a pungent odor until it is fully cured. Only experienced it a couple times in the last 20 years. eric
Jul 08, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Search
I have a kenmore freezer kinda new, my kids unplugged it, i came to find this problem on Dec 19, 2010 when i was cleaning and came about a heady smell around my freezer... ENTIRE frozen food went spoiled, the smell is unbareable. I discarded of it all, cleaned freezer inside very well... however, the smell remains inside freezer, a very foul odor.
I put arm & hammer baking soda, smell is still in it.
I put coffee grounds inside freezer, Today Dec 20 i bought activated charcoal & put it inside freezer. Question is: Do i need put water or alone and do i need to plug freezer...
IN DESPRATE HELP! Bronx, NYC
May 21, 2008 | Cameras
Freezer smell
could be that your freezer is leaking gases some leaks are fixable but if its an internal leak you will have to replace the complete appliance
Aug 15, 2007 | Turbo Air TGM22RV
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
