Question about Konica Minolta Office Equipment & Supplies
Tray 1 not recognized - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
Model ???????????????????????
Posted on Jan 10, 2016
The printer recognizes tray 2 but it will not print to tray 2.
The printer will not print from any tray if tray one is pulled out. the paper path from any other tray still goes through tray 1\'s feed path (little slit in the front of the tray). if tray one is not in the printer it will not pull from any other lower tray.
Jun 03, 2014 | Lexmark T630 Laser Printer
Printer recognizes tray 2 but will not print from tray 2.
its not reading there is any paper in the slot so will not load from this draw. the is a switch that when paper is installed it lifts it to tell printer paper loaded. like any switch they can fail.
Jul 03, 2017 | Lexmark T630 Laser Printer
Our imagerunner 5000 doesnt recognize full tray 1 or full tray 2, we have to use tray 3....what causes this?
I don't know if this may be a bit to late???? Have you looked behind the the top two paper trays for any paper wedged behind the trays them self? There are switches behind the tray for paper present and paper size.... You may also have broken switch in the back of the copier..... There could be a few other things..... Good Luck
Dec 09, 2011 | Canon imageRUNNER 5000 Copier
My Lexmark T640 does not seem to recognize paper "tray 2". I want to print legal, but it only prints from tray 1. How can I get the printer to recognize and use tray 2 so I can print legal AND letter?
2 things
1st make sure the paper guides are set correctly on the trays for legal make sure it's exactly on legal or it put the tray into universal mode. (To clarfiy the guides in the back which allow you to put legal in the tray.)
2nd Go into menu and then to paper menu and adjust/ confirm the settings for tray 1 and 2. Based on your question tray 1 is letter and tray 2 is legal, so make sure both of the tray size and type are set correct.
Oct 21, 2010 | Lexmark T640 Laser Printer
I have an AR-m237 that tray 1 will not pull paper, tray 2 works fine
is tray 1 recognized if not the little switch on the back of the machine behind tray one in blown, other wise you have to see if the rollers turn
Jul 08, 2010 | Sharp AR-M237 Copier
Won't use tray 2 when tray 1 is empty
Have you tried checking that tray 2 has the same paper type as tray 1. If your machine is network attached, you can access the embedded web server (where device settings can be adjusted) by entering the device IP address into a browser. Find the web address from the machine by going to menu (key icon), reports, then arrow over to network set up page. NSP is a 1 page report which will tell you the IP address. Go to a web browser and type in that IP address. Should take you to your device web page. From that page you can change the device settings (click on settings and then paper menu). Check to be sure that the same paper type is set for both tray 1 and tray 2 (and be sure that tray 2 is showing up on the list). I had to power the printer back on for it to recognize tray 2. Hope it helps
Feb 04, 2010 | Lexmark C544dn Laser Printer
Ricoh Aficio 240W is limited to bypass tray use only. Cannot set it to recognize the paper tray. I've seen the tech's reset it.
Enter into service mode:
1.Press the clear modes key.
2.Enter 1-0-7.
3.Press the clear/stop key for more than 3 sec until the service program menu appears on the touch panel.
Select paper tray setting,and set the new value.
Jul 29, 2009 | Ricoh Office Equipment & Supplies
T642 wont recognize tray 2 or duplex
You need to be sure you add the duplex unit and tray unit in the windows driver. The "device" tab will allow you to add the duplex and tray to the
printer.
Apr 29, 2009 | Lexmark T642 Laser Printer
Panasonic FP-7735 won't recognize paper tray
Can you hear the tray rise when you close it? Is there a red, blinking "out of paper" light on the control panel? Can you select the tray manually?
Or, you had a power outtage, or gremlins, and the settings reset itself, you can go in to service mode and set the trays up again.
Hold the following keys to fire up Function mode. "Function + Original Size + 3". Hit 5 for F5 mode. F5-14 is tray 1. If you have a duplex(ADU) unit installed, you'll want to check out tray 2. F5-14 is tray 1, F5-15 is tray 2 all the way down to F5-18.
Key in whichever number you need.
0: none (no tray installed)
1: Ledger
2: Legal
3: Letter
4: Letter-R (landscape)
5: Invoice
Jan 24, 2008 | Panasonic FP-7735 Black and White Copier
16 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
