Question about Electronics - Others
I have samlex 600 watt voltage inverter -12vdc to 120vac pure sine.ihave never overloaded or dropped unit or reverse polarity hookup.any chance you can fix mine?
    Top Expert:
  • Electronics ... Master
  • 81,423 Answers
Replace the inverter diodes, they are most likely burned out
Posted on Jun 18, 2009
I'm trying to run a 750 watt whirlpool compact microwave with a 2500 watt Cobra inverter. The microwave runs normally, but it won't heat. If I plug it in at my house it heats fine. I'm stumped. I load...
I assume your not using a pure sine wave inverter. A lot of electronic devices won't work on a lower cost inverter (modified sine wave) that has a square sine wave, either invest in a true sine wave inverter or don't run sensitive electronic equipment, I'm somewhat surprised you didn't damage the circuit board in the microwave...Below is a link of a inverter that would work if you want to spend the money for one.
2500W 5000 Watt Power Inverter Pure Sine Wave 12V dc 110V 120V ac LCD...
Feb 05, 2018 | Electronics - Others
User's manual pure sine inverter
http://www.donrowe.com/user_guides/samlex/ssw_series.pdf
May or may not be identical to what your part number is but the general guidelines are the same.
If you are looking for the schematic, the manufacturers keep a tight lid on those to protect intellectual property as there are several ways to achieve the sinewave synthesis, and some are under patent or are under license.
If you understand the principles of a Class A audio amplifier, you should be able troubleshoot this type of inverter.
Jan 15, 2012 | Electronics - Others
Need owners manual
Without knowing make or model other than 600 Watts and pure sine output:
is for a series of pure sine inverters, yours should be similar enough to the 600 Watt version to be of practical use.
Jan 14, 2012 | Inverter 600 Watt Pure Sine Wave
Can you daisy link two inverters together positive to positive neg to neg ac out to increase the watts
This will cause big problems. It will not work and will likely cause both inverters to fail. Power inverters must create the 60Hz sign wave from a crystal controlled internal frequency driver. It's like a clock that keeps the timing at 60Hz. 2 independent units will have slightly different clocks both in time and frequency. This would cause the output waveform of one unit to be out of phase with the second. If they are out of phase, they will look like loads to each other and likely fail. It would be possible if the inverters had a way to link their clocks or use only one clock. This could be designed in however I have never seen this feature. You can hook up multiple inverters to the low voltage side (12VDC), just don't hookup their 120VAC output side. Hope this helps.
Jun 07, 2011 | Inverter 1000-2000w Peak Surge Power
My inverter is in alarm and won't produce 110 power. Checked input voltage and it is correct.
I have had this happen a few times.
Sadly replacement is the Best option.
Repairs can be %75 the cost of a new one.
The best invert we have been using is a Pure Sine 1500 watt inverter.
Sad news but hope this tip helps.
R/
David
Jan 26, 2010 | Coleman Cable Coleman 1000 Watt Power...
Red fault light comes on after about 10 mins and
Had a similar problem with the same inverter BUT to include a failing cooling fan.
NOTE:
Take it back and get your money back as soon as possible.
Replaced it with a pure sine inverter 1500 watt that is kicking **** 24 seven days a week on my solar / wind power system.
RECOMENDATIONS:
UPGRADE.
Hope this tip helps.
R/
David
Dec 24, 2009 | Inverter AIMS 1000 Pure Sine Wave Power ...
My aims 2000 pure sine wave inverter is pluged to 2 240amp/h 6 volt batteries. When | plug in a 1800 watt hairdrier i get an alarm as if the batt. were to low. they are new and at full charge. is the load...
Your inverter has a peak of 3000 watts rating and should power that hair dryer. Make sure your batteries are in good shape. The inverter can only put out what it takes in. 1800 watt demand on the inverter requires 1800 watts from the batteries.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 14, 2009 | Inverter Aims Pure Sine Wave Power...
Run a CPAP on a power inverter
I would not do this, you really need a pure sine wave inverter to guarantee the safety of your CPAP machine. At the price they are selling this device it could not be pure sine wave. 150W pure sine wave would be $70-$100.
Mar 05, 2009 | Thermal Engineering Corporation I-Tec 150...
Electronics - Others Logo
140 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
