I needs code for polar control 9045700 - Televison & Video
F28 error code on Maytag front loading washer
The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) has failed.
Possible Causes
- Reversed polarity or mis-wire along with open ground switch(es).
- Communication cable from CCU (MI3) to MCU is damaged.
Procedure for reversed polarity or mis-wire
1. Clear error code.
2. Unplug washer or disconnect power.
3. Check the white wire on the RFI filter to ensure correct polarity.White wire needs to be toward front of washer.
4. Check outlet for correct polarity. To check within washer for polarity at the RFI, white to cabinet ground must be 0 volts.
5. Check that the ground switches of the toe panel and rear panel are correctly closed.
If switches are good ,replace the CCU.
Oct 14, 2016 | Maytag Washing Machines
Tengo un control remoto polar 9058003 y no tengo el codigo de una tv lg cinemaster champ
Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. Electrohelponline
Apr 01, 2014 | Televison & Video
Dvd code polar dvd
258,255,250,259. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jan 21, 2014 | Philips SRP2003/27 Remote Control
Polar code 9074993
Codes are 4257 4477 4499. If you wish to get more, http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 10, 2013 | Televison & Video
Polar 9058006 code
What is the code for TVs LG universal control Polar 9058006
Jun 09, 2013 | Universal Remote Control Televison & Video
I have a remote control POLAR 9058006, my tv is SHARP, any body have the codes?, please, i need it
Codes to check with Sharp brand TVs are 091,043,082,096,011. If you wish to get more details, check this site. Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Mar 29, 2013 | Televison & Video
I need codes for Polar remote control model 9045699 for use in LG TV
0821,0863,0892,0873,0810, 0000. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 10, 2013 | Televison & Video
I NEED CODES POLAR UNIVERSAL REMOTE CONTROL MODEL 9058007
Setup codes to Sony TV are: 0128 0013 0002 0071 0380
Aug 21, 2012 | One For All Televison & Video
Install manual says to use 3- 16AWG 'polar' wires to connect condensor to indoor unit & 2-22AWG 'non-polar' wires for control. What is'polar' wire?
Polar refers to polarity. When dealing with the power you have to use color coded wire usually red, black, and white. This is so you don't incorrectly hook it up and cause a short. On the control it does not matter if you use coded wire. It is just to complete a 2 wire sine circuit for a thermostat. Hope that helps.
Jul 01, 2009 | Mitsubishi Heating & Cooling
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
