Question about Samsung Heating & Cooling
Capacity miss match - Samsung Heating & Cooling
What is the engine capacity horse power for a 351 ford cleaverland .
351 "C" 4V 1970-1973 Cleveland
http://www.carmemories.com/ford-engine-specifications/351-engine-specs/351c.html
would have thought engine capacity would be what they wanted
351 cubic inches which converts to 5.75186 litre capacity
horse power in the link above is 300 BHP (brake horse power)
I have no idea myself but found the car memories web site that states the engine specifications and I hope it is correct and matches your engine ?
most likely it would be rounded up to a 5.8 litre capacity
Jul 07, 2017 | Ford Cars & Trucks
My kodak easy share was not support another sdbcards
SD Cards are of different types size and capacities.
Avoid higher capacities and faster speed for older devices.
You will need to match for a compatible type.
How to Buy an SD Card Speed Classes Sizes and Capacities Explained
Jul 16, 2016 | Kodak Cameras
How many watts per channel?
Hi Peter.
Your question is fairly open, so I'll give a couple of answers to anticipate:
  1. If you're wanting to match the amp to your speakers, you want to go above the power rating of the speakers, but not hugely so. If you have 40 watt speakers, you don't want a 40-WPC amp because it'll be running at full power to use the speaker capacity, and it'll probably sound awful. Amps are much smoother when you're not coming close to their capacity, and your music will sound better. Likewise, a 40 watt speaker running at 40 watts will also sound pretty bad. The limits on speakers usually allude to damage thresholds, or limits where they'll distort like a stump-talking politician. Talk to a dealer about how much 'THD' (Total harmonic distortion) the amp has at different power levels, and how to match it to your speakers.
  2. If your goal is to be able to announce your presence from a block away from the subsonic thudding escaping from the interior, you'll still want to look at the speaker ratings and spec the amp perhaps 50-100% higher than the speaker capacity. Full power on a big subwoofer will still sound crummy if you're driving it to capacity, but in some cases people won't care so long as it's loud. (I don't advise this route - I'll tell you from first hand experience with loud environments as a younger person that being several decades older and constantly missing parts of conversations is no fun)
Hoping this helps!
D
Nov 30, 2015 | Car Audio & Video
MY CAPACATOR FOR PUMP ON JACUZZI MODEL DC25 BURN
contact the MFG's website tech support
Dec 29, 2014 | Jacuzzi Home
I want to install a multi split air conditioner system. Must the total of the individual capacities of the indoor units be smaller or bigger that the capacity of the outdoot unit?
Ideally, the indoor total would be matched to the outdoor unit, but ideals are only ideals. The indoor total may be either greater or less than the outdoor unit - try for the closest match either way.
Jul 29, 2014 | Midea Heating & Cooling
Are all computer batteries the same size?
The short answer is "No"
The long answer is:-
Physical size, input and output voltages, output capacity and the connection type to the PC varies from one PC to another.
If you are asking about batteries for your particular PC, then there are four things that need to match the PC's requirements, they are-:
Physical size, has to match the space provided for the battery.
Voltages, the output voltage from the battery to the PC must match the voltage required by the PC. (This can be found in the handbook, on the back of the PC, or the manufacturers website.
Battery Capacity, this is stated in one of two ways. either, in Wh,(watts per hour) or Amps, the higher this number, the longer it will run your PC.
Connections, this must marry-up with the connections on the PC.
For instance, the battery information label for my Inspiron 1720 reads as follows:-
Rating: 11.1v === Capacity 56Wh which means,
Voltage; 11.1 volts (=== DC), less than this and the PC will not run, more than this WILL damage the PC
Capacity; 56Wh means, if the PC uses 56 watts per hour, it will run the PC for one hour. If it uses 28Wh, (56/2=28), it will run the PC for two hours.
The higher the Capacity, i.e ??Wh the longer it will run the PC and will not harm your PC but, increased capacity batteries commands a price.
When it comes to the Power Supply Unit, (PSU), or "Charger"
Input: AC 100-240 volts ~ 1.5A 50/60Hz (~ refers to AC)
Output: DC 19.5 volts = 4.62A (= refers to DC)
Input from the wall socket of Alternating Current anywhere between 100 and 240 volts at 1.5A at 50 or 60 Hertz. In other words this PSU will work world wide with the right plug adaptor, (if needed), to convert the existing plug to the wall socket of the country you are in at the time.
I hope you find the above, informative and useful.
Kind regards,
Ron.
Jun 15, 2014 | Dell Inspiron One 2305 Desktop Computer...
I need to know what the towing capacity is for my 2000 chevy silverado half ton is?
Tow capacity for that vehicle is about 10.000 lbs (adjusted for wear and age). This number reflects max tow capacity with good tires (proper rating and good condition) with all suspension components in good used condition. The capacity of your tow hitch must also match your load and assumes proper trailer weight distribution and tongue weight.
For best results, I also recommend that you use a good quality synthetic gear lube in the differential and synthetic fluid in the transmission, as well as a trans cooler if not so equipped.
Jun 16, 2010 | 2000 Chevrolet Silverado
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Sm8525079 what is the capacity of this washer and what is the capacity of the matching dryer?
Hello.
The capacity of your washer is 3.2 cu ft and the dryer is 6.0 cu ft. This is pretty much a standard for newer top load washers and dryers. You can get bigger but it is not that much bigger.
Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Gigabyte GA-8VM800PMD-775 @ 1.5gb memory
This is the website link for your board on gigabyte website. http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2159&ProductName=GA-8VM800PMD-775 Suggest you have a faulty piece of ram or a clock speed miss-match. your board supports up to 2gb of memory.Try also reseating the memory. Let me know how you get on? chris http://www.motherboardsrus.net
Jun 06, 2009 | Gigabyte GA-8VM800PMD-775 Motherboard
Heating & Cooling Logo
44 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
