Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
6200 is not sucking through hose - Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
I love the machine because it sucks up the dirt but it also sucks up the rug fibers and is clogging the hose. How to I clean out the hose?
Try this - run a strong string with a small weight attached down through the hose. Tie a small rag or a sponge to the end of the string and pull it back through the hose.
Dec 04, 2016 | Vacuums
Doesn't suck when hose is in
If your Nilfisk doesn't suck with the hose on it, and it sucks from the body with it off, it means that the hose is blocked. I have had Nilfisks when I worked in hotels and have seen this before. Push a broomstick down the tube from both ends after removing the metal handle. There is a rubber seal with a plastic ring. Remove the ring and the seal will stretch and come off the ball on the end of the metal tube.
Mar 24, 2016 | Nilfisk Vacuums
My Miele vacuum's hose has stopped sucking-help!!
Sounds like you might have something caught in it. If you have another vacuum with a hose, use that machine to suck out the clog in your Miele hose.
Sep 06, 2014 | Vacuums
Fixing the overstretched hose on the helix bissell vacuum
Hey Trinidad! Sorry to hear the hose sucking together. You may want to purchase a new upholstery hose.
Here's a quick link to the BISSELL website.
http://www.bissell.com/parts/?cid=ccsocial
Feb 22, 2013 | Bissell Vacuums
Accessory hose not sucking
Try taking the hose off, and making sure it is not stopped up, either in the hose, or where it attaches. Straighten a wire coat hanger and run down the hose to check for obstructions.
Hope this helps!!!
chad
Oct 08, 2008 | Dyson DC14 All floors Bagless Upright...
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Minuteman ambassador jr. shampoo extractor
roro, There are two possibilites: One is that each hose does something different (suck and exhaust) or both suck. Find the one that sucks. That should be the one that you hook tools to now. If the attachment has an electrical connection, it will be needed to do scrubbing. If the shampoo unit is from a different brand, you'll have to make up something to do that. If you do, be certain that the connection is fully taped up so no liquid can get to it!!
Dec 06, 2007 | Vacuums
SteamVac Supreme Vacuum Problem:
Does this have the slot in front of the dirty water tank for the hose? If it does and the hose isn't installed, there is a block that you put in when the hose isn't being used. If not there, then it will blow air and won't suck up.
Nov 11, 2007 | Hoover F5832-910 SteamVac Supreme Vacuum
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
12 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
