Question about Cross Cst/Berger 58 Ilm Xt Indoor/Outdoor Pulsing Beam Laser Line Level New
Loss of horizontal line - Cross Cst/Berger 58 Ilm Xt Indoor/Outdoor Pulsing Beam Laser Line Level New
H line
Your H line or Horizontal line is caused by a loss of vertical drive. As intermittent as you have, probably bad solder joint at the vertical drive IC. If you have no experience in soldering, then my recommendation is to have it professionally repaired.
Dec 25, 2013 | Televison & Video
BLACK LINE
sounds like a video board died..
Apr 28, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Horizontal line on screen sometimes
Generally horizontal lines are caused by the panel failing, you can try a new tcon but I don't think it will help.
Mar 01, 2018 | Philips FTR9955-17 DTV Receiver
STANDBY INDICATOR FLASHES FOUR TIMES.
this is a indiciation of loss of vertical deflection. is the a thin horizontal line? I have found feferences that capacitor c517 in the horizontal cuircit was shorted cause this .. cant be sure... also other components that might be at fault is the vertical ic 1509 transitor q1505 vertical buffer.
Oct 28, 2010 | Sony KP-43T70 43" Rear Projection...
Describe your Sansui DTV2760 27" TV Problem Loss of picture. A very thin line goes across the screen.
vertical line = bad horizontal output transistior
horizontal line = bad vertical output transistor
Oct 05, 2009 | Sansui DTV2760 27" TV
Vertical line picture
problem is caused by the loss of horizontal deflection signal. It is quite surprising that the entire unit is still working, since usually, a loss of H-Out will disable the entire set. Problem can be as simple as loose solder connection to a more complicated defective horizontal circuit. I would suggest havint it checked by a professional TV tech.
Jul 16, 2008 | Proscan PS36500 36" TV
Panasonic PT-51HX43G no picture
You have a loss of horizontal deflection. It is a possibility that you have burned that line down one or more of the CRT's. The repair wil take the help of an expert since the horizontal section puts out signals of 1200 volts or more.
Jun 09, 2008 | Televison & Video
Aspire 5600 gets horizontal lines on lcd
The horizontal line means that there is a loss connection in the horizontal projection of the monitor. This can be resolved by fixing the horizontal panel board that gives error. this require quite expert in the LCD troubleshooting. However, if you believe that you can do it, ok you may proceed.
please donot rate me if this not solve the problem. because i need more higher rating. just notify if you need more solution am here to assist. melnavz
Apr 09, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Horizontal White Line
Sounds like something is getting hot causing voltage loss or drive pulse loss to the vertical IC. Maybe you have a bad solder joint. Try tapping the circuit board around the vertical section. A capacitor could be heating and opening up. Stargazer Also you might try using circuit cooler spray and make the problem show up.
Apr 19, 2007 | Sansui TVS2750 27"
Horizontal Lines in picture
CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. HOPE THIS HELPS!
Jan 12, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Cross Cst/Berger 58 Ilm Xt Indoor/Outdoor Pulsing Beam Laser  Line Level New Logo
37 people viewed this question
Top Cross Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cross Measuring Tool and Sensor Expert? Answer questions, earn points and help others
