Question about Delta 40-695 20 Inch Variable Speed Scroll Saw
How to replace the circuit breaker on a delta 20 inch scroll saw
5 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: My Delta 10 inch table saw stopped working in mid-saw
you have to use a meter and check the voltage at the switch and to the motor.
Posted on Oct 09, 2009
  • 6 Answers
SOURCE: have a 24in scroll saw over 20 years old looking
Check out this site.
http://www.owwm.com/mfgIndex/detail.aspx?id=1141&tab=3
Posted on Dec 12, 2009
SOURCE: The motor on my delta 10
This saw tends to have a problem where the belt rides "outside" the V-grove. Check that the belt is actually installed into the V-grove, and that the grove is in line. Mine was installed (at the factory) with the shiv back to front, so the belt would catch, and kick out. Maybe the same issue.
Posted on Mar 03, 2010
SOURCE: I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Posted on Mar 04, 2011
I need a manual for a Delta 40-500 15" hobby scroll saw
The closest I could find is the Delta 40-530 16".
http://documents.dewalt.com/documents/English/Instruction%20Manual/Delta/En%20900621.pdf
Here is a parts diagram for Delta 40-500 type 1
Delta 40 500 Type 1 15 34 Scroll Saw Parts
Here is a parts diagram for Delta 40-500 type 2
Delta 40 500 Type 2 15 34 Scroll Saw Parts
Oct 09, 2016 | Saws
How to change a fuse on delta 20 inch variable speed scroll saw
there is a delta web site that gives you a down load manual if you don't already have one.
it shows you where the fuse is located on page 10 - fig. 10.
here is a link to the page
Jan 09, 2015 | Delta 40-690 20-in Variable Speed Scroll...
Owners manual for a 40-150 Delta scroll saw
Hi, I found something on amazon, take a look here: Amazon com Delta scroll saw manual. I hope this was helpful. cheers
Dec 17, 2010 | Delta 40 680 Electric Scroll Saws
Delta Side Kick table saw will not start,
If there is no response at all, check the circuit breaker on the motor. There is a heat triggered breaker there. That is the most common cause of this. If that is not the case, please update this and we'll look further.
Dan
Feb 01, 2010 | Delta Saws
Can I mount a Delta 36-T30 T2 30-Inch Fence and Rail System on my
I just installed a Delta T2 fence on my 10" Craftsman Table Saw. It's 27" deep. The bushing either could be relocated or you could use spacers on the front, back, or both on the saw to get the required distance. Also, you'll have to drill new holes, however, I used one of the existing holes in the front and back of my saw as well.
Mar 11, 2009 | Delta 36 T30 T2 30 Inch Fence And Rail...
Delta 40-695 20 Inch Variable Speed Scroll Saw Logo
32 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Delta Saw Expert? Answer questions, earn points and help others
