Question about Boating
Looking for Troubleshooting and instructions manual to find problem and repair a 2000 Mercury 40 HP that will not start
My 2000 Mercury 40 HP outboard mortor Will not start, it spending real fast but won't start. Is there some type of troubleshooting manual that would show me, locations of each part and how to test for fire and fuel. Thank You very much. DD
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,190 Answers
Remove spark plugs and check compressions are over 100psi then put plugs back in plug caps and hold them against the head and crank over and see if they spark ! if yes then remove carb airbox cover and open the throttle fully and sqwert some fuel in the carbs try to start then with 1/4 throttle and choke on ! if starts but then dies then you need to clean the carbs and fuel pump , check diaphrams not hard !
Posted on Jun 11, 2014
  • 187 Answers
SOURCE: 1994 40 hp mercury force outboard with no spark
If the fuel was not treated with a fuel stabilizer than you probably have a varnish build up in the carburetor. This varnish will clog fuel needle valves and jets. You need to disassemble the carb to clean the jets and needle valves. Sometimes cleaner is not enough you need to us compressed air to blow out the jets. Good luck.
Posted on May 13, 2009
Editor925
  • 285 Answers
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Posted on Jun 20, 2009
finish line
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
SOURCE: 1993 40 HP 4 cyl. Mercury outboard: Running along
I solved it with no help from the professional assistant team. Thanks for no help till I send money...DON'T THINK SO!!! Thanks for wasting my time.
Posted on Sep 04, 2009
SOURCE: 30 hp johnson outboard motor trys to start. It
1985 30 hp johnson used a cdi system(solid state, no points) check the power pack.
Posted on Mar 09, 2010
Mercury 1989 60 HP Outboard Motor manual to find gas to oil ratio
50:1 But if your doing mostly low rpm cruising (trolling) then you could reduce that a bit to 75:1 to help reduce smoke. If you do mostly mid to higher rpm cruising, then 50:1 (1 pint to 6 gallons. )
Or 200mls in 20 liters if your Canadian.
Feb 26, 2016 | Seloc Mercury Outboard Repair Manual, 1965...
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
What year is my mercury 40 hp (402)please the number is 9034091
According to marineengine.com, it looks like it could be in the 1983 sequence of serial numbers.
http://www.marineengine.com/mfr/mercury_models.html
Aug 29, 2011 | Seloc Mercury Outboard Engine Repair...
I'm looking for a downloadable version of the service manual for this motor. Any Ideas? It's a 1994 mercury XRi 175 hp outboard
I couldnt find one anywhere for my merc 75hp 2stroke-ended up buying a service manual $70
Oct 09, 2009 | Boating
Hi i am looking for a repair manual, online, free would be best,for a 7.5 hp mercury outboard motor - no idea what year but must be early 90's at best. It won't start, fuel drips from under the head and...
Mel's Marine Service Inc. stocks those repair manuals and will ship them. I believe they run about $50.00. There phone number is 541-689-0136. They are open from 8-5 pacific time mon-fri and 9-2 on saturday.
Oct 08, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
131 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
