Question about Kitchen Appliances - Others
Plastic conection plastic parts
Expresscard
I have in the Acer a sata conection and a usb3 on the same card but search around and before you buy any thing there should be a plastic part that comes out, remember the shape of it only theres a few different ones on the Acer, you could go to your browser and type in Acer and your model followed by support there might be the plastic part showing you the shape of it before buying, hope this helps ;)_
Nov 10, 2013 | Acer Aspire 5315 Notebook
1986 mercedes brake and turn signal lights don't work and fuse is ok
check the bulb cluster unit in the back make sure that the harness is conected properly also some times the plastic welds that keep the metal part to the plastic part come apart and need glueing back to gether also check bulbs and fuses unlikley it will be a wiring problem but it is possible
Aug 15, 2013 | Mercedes-Benz Cars & Trucks
My wolfgang puck 1.6 hp professional blender will not spin the blades if there is anything in the blender container.
This is not really the solution it is just a better description of the problem that I am also having. This is a great blender however the part where the cup blades conect to the motor is made of plastic.
So what has happened here is that the motor is fine, the cup is fine only the plastic part that makes the motor turn the blades has worn down therefore rendering the blender useless. I would like to know where I could get this small part to change on my blender!!!
Jul 30, 2012 | Wolfgang Puck 1.6 Hp Professional Blender...
No spring in door
Hi there Mathew, yep your diagnosis sound correct to me the LG dish washers have a string with a plastic lug that conects them to the springs. The plastic lugs and known to brake off the part number for the replacement strings is 4933ED3002A you will need two of these one per side. I hope you find this usefull please contact me if you need any further asistance. Regards Gary.
Nov 23, 2011 | LG Dishwashers
Plastic piece that conects shifter broke was hard to get out of park the last few times seems to be common how hard is part to get and replace
Stop down at local dealer, their parts dept should stock it & while there get a photo copy of the exploded view - (makes it alot easier to install)
Jan 10, 2011 | 2005 Dodge Ram 3500
The mechanism in the base that is black plastic with four wings and conect and turn the chopper is broken. how can I get it?
Danoz Direct have access to spare parts. Type the name in to your browser for your nearest agency
Please rate my help++++Thanks for using FIXYA
May 23, 2010 | As Seen On TV Magic Bullet Food Processor
Instal psp power switch (plastic exterior part)
You will have to open it up and void your warranty, let me know if you would like assistance opening up your psp.
Nov 29, 2008 | Sony PlayStation Portable (PSP) Slim...
GE JVM1860SF001
Be sure the oven is unplugged.
There are two Phillips head screws on the very top of the outside of the cabinet above the vent.
When they're removed the vent grille just snaps out.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 12, 2008 | GE JVM1860 Microwave Oven
Kitchen Appliances - Others Logo
97 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
