Question about Zanussi Washing Machines
Zanussi zwt 71401 wa not emptying water - Zanussi Washing Machines
Why does water softener drawer still have water in it at the end of cycle
It is clear water right? The filler tube flushes as it empties and it always has a small amount of flush water in it.
Jul 26, 2014 | Zanussi Washing Machines
My zanussi dryer keeps stopping saying water needs emptied but it is always empty. The vent valve is always falling out is there supposed to be something to stop this?
I read the posts then checked my drier. I found the valve at the back of the water tank was blocked with fluff. So I tilted the dryer and unscrewed and removed the valve so I could remove the trapped fluff. Problem solved.:-)
Jan 16, 2012 | Zanussi Dryers
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Aug 30, 2011 | Zanussi Washing Machines
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Zanussi will not empty
Hi
remove filter from bottom of machine and clear any debris which is in there and check impeller is turning ok.
regards
Mar 01, 2009 | Zanussi ZWF1430W Front Load Washer
Water leak on Zanussi tc7102 dryer
I had a similar problem. There is a 'o' ring on the plastic part that keeps coming out. This 'o' ring is not big enough, you need to replace it with a thicker one, preferably one made from a harder material.
Feb 28, 2009 | Zanussi TC7102W Electric Dryer
Zanussi DCE 5655 dish washer
Unplug at night if doesn't work change the L subport conversion chamber and remove the restricter plate
Feb 27, 2009 | Zanussi 21 in. DCE5655 Free-standing...
Zanussi Aquapulse DE6544 not emptying
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
The Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Mar 27, 2007 | Zanussi F1245W Front Load Washer
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
