Question about RCA P61960 61" Rear Projection Television
Projectors need to be adjusted i guess they moved when TV was transported
  • scroby44 May 11, 2010
    Mr Wizardtex....On this model RCA, the mechanical convergence is on the front of the tv behind the lower panel.
Looks like I'm looking through a fish lens. What can I do to adjust?
Posted on Apr 20, 2011
  • 2,237 Answers
Do not move crts manually. go into the menu and adjust the picture's convergence.
Posted on Aug 19, 2009
I have sound but no picture
Posted on Jul 24, 2011
    Champion:
  • 205 Answers
Two adjustments possible. Mechanical convergence from the back of the TV and Electronic convergence from the user menu Good luck
Posted on Jul 07, 2009
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture is too big for screen, projector wont zoom enought to fit screen
you will need to move your projector closer to the screen. you will need to zoom all the way out and physically move your projector closer to the screen and then adjust your focus.
Jun 01, 2010 | NEC PROJECTOR ZOOM / THROW LENS, 1.2 TO...
Need to change the "Throw"
the throw is adjusted by the zoom on the lens, getting a different lens (or projector suited for this situation), or moving the projector.
Aug 07, 2009 | Sanyo PLC XU35 Multimedia Projector
Projection lights
You need to take the Toshiba remote that came with the machine and go into a menu area that deals with convergence. Here's what the manual says:
This TV used 3 separate TV tubes, red, green, and blue. The R, G, and B images are pojected onto the screen wheree they converge to form a full-color picture. You can see a clear picture only when the three images converge correctly. Corvergence my drift over time, or if yo move the TV. I you can see clear images on your TV screen skip this procedure.
Make this adjustment only after the TV as been on for at least 30 minutes.
Press the TOUCH FOCUS (auto convergence) button on the front of the TV at the bottom.
The TV will enter into the convergence mode and adjust the converge automatically (that's what it says.)
TO ADJUST IT MANUALLY:
Press MENU, and the press < or > until the PICTURE menu appears.
Then press UP or DOWN to highlight CONVERGENCE.
Press < or > to display the Center Convergence menu
There's a lot more the book says, but, I can say from experience that you just go through the different sub areas of this menu and converge each color separately, and bingo, it's fixed.
Good luck.
Sep 06, 2008 | Toshiba 43H71 43" Rear Projection...
Jvc rear projector tv
only through the convergence settings menu. If that doesnt adjust it, you will need new ICs. If you need more assistance please respond to this same post
Aug 15, 2008 | Televison & Video
Problem with an 8mm Cine Projector. (A What ????)
Is there a camera or video club where you live ? one of the older members may have had experience of this, and be able to help you
Mar 21, 2017 | Raynox Cameras
Can't watch footbal
NOTE: ----DO NOT TOUCH THE CONVERGENCE BOARD " -------
1. Bring Up 1 Projector Light 2. Bring Your Color Convergence + Sign and Should Be Center In Your TV 3. If Not Adjust Center with The 2 Tabs Just Above That Projector Tube You Have Lighted 1 Tab Will Move + Sign Horizontal Then Roll The Other Vertical Then Roll..U Will See--" 4. Once Your + Sign Is Center Turn Up Your 2 Other Projectors Make Sure They Are Able To Adjust Across The + Sign You used 1st Make Sure the 2 Other + Signs Move Left And Right And Up And Below The Vertical and Horizontal Lines. If Not Adjust There Tab to Make This Possible. 5. Using Your REMOTE Converge The + Signs Together. ---------------- IF YOU MESSED WITH THE CONVERGENCE BOARD ------------------- 6. Now Lower The 2 Lights So Your 1st Projector Is Lighted 7. Bring Up A Menue On Your TV -- Look At It ...Are The Lettering Center and Square ..?? 8. If They are Lower That Projector and Light Your Projectors 1 At A Time To Verify Letters are Center and Square. ---------------If You Have To Adjust The Menue To Bring Center And Square -------- 9.Looking At The Convergence Board You Will See 3 Rows Of Adjustment Dials Each Row Is For 1 Projector. ---TAKE NOTE TURN THE ADJUSTMENT Slowly--- 10. Locate The Row that will adjust The Projector You Have LITGHTED".... 11. Label On A Paper What Each Knob Will Do To The Screen Very Help-Full 12.Adjust Your Letters Dead Center and Square then Lower That Projector Light And Bring Each Projector Lighted At 1 Time To Verify Menue Is Center And Square. 13.Leave On Your 3rd Projector and Bring Up Your Light On The 1st Projector 14. Adjust the Letters Of Your 1st Projector Over The Letter Of Your 3rd Projector 15. Switch To Your Convergence + Sign To Help --Turn Knobs Slowly --- 16. Make Your Letters Merge Together And Your Lines Square. 17. I Use The Top Letters and Lower Letters And Keep The box Square 18. Hey If Your Projector Colors When Looking Through The Rear Of The TV Are Not Equal With Take And loosen The Wing Nuts And Turn The Lens To Focus the Color and Make Narrow Or Wide....All 3 - Equal DO NOT GET UPSET THIS WILL TAKE TIME MAYBE ALL DAY SO RELAX HAVE FUN" Do Not go Sticking Your Hand Into The TV While TV Is Plugged into The Wall" ---
Dec 16, 2007 | Philips Televison & Video
Convergence problem
We need a better description of what you mean by shadowing. However I am assuming: 1. You mean it ''bleeds'' off to the right when you have something with a hard red/blue drive. 2. When you turn the contrast and color down a bit it gets better. unfortunatly I cannot tell you how to fix convergence, but I can think of some other possibilities. In this case the red/blue emmision of the crt is dying off and going into saturation when driven hard. To fix, replace with a new picture tube/crt. In some cases you can get a little more life out of that tube (with a watchable picture) by having the screen, focus, cathode bias, and drives slightly readjusted. It will take someone with experience in doing these adjustments on a weak tube to get it looking as good as possible. Given the construction of the cathodes (guns) in that crt, only a very low level crt reactivate should be tried on it. The hard rejuv most crt testers give is highly likley to completely destroy the cathode on that crt.
Mar 22, 2006 | Toshiba 55H70 55" Rear Projection...
Distorted Color and geometry of Picture
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Nov 03, 2005 | Panasonic PT-47WX49 47" Rear Projection...
RCA P61960 61" Rear Projection Television Logo
285 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
