Question about Dell Computers & Internet
My dell optiplex 320 wont play sound and tell me no audio device installed. the outer case also shocks each time i touch itGrease
    Master:
  • 569 Answers
You get a shock means there is earthing problem get it fixed by an electrician
http://www.dell.com/support/home/us/en/04/product-support/product/optiplex-320/drivers
Posted on Nov 06, 2015
shoib127300
  • 55 Answers
SOURCE: dell optiplex 320 mobo to new case
The formfactor for dell systems are very specific.The screws for the boards or the slots donot  usually match with other towers.Please check with a local tech and check the size and the screw slots on the motherboard if any
Posted on Mar 17, 2009
jcoady
  • 79 Answers
SOURCE: Software Driver reuired
http://support.amd.com/us/gpudownload/windows/Legacy/Pages/integrated_mce-xp.aspx?type=2.7&product=2.7.5.3.3&lang=English
Posted on May 31, 2009
SOURCE: my dell optiplex 360 model pc have built in
The optiplex 360 does come with internal speakers(it's in the spec sheet as optional), we bought them for our entire IT department and they worked fine on XP and vista, but when we put 7 on them, we can't get the internal speaker to work.
Posted on Dec 09, 2009
  • 3 Answers
SOURCE: No sound on dell optiplex gx620 on Windows XP.
This should help you out
http://download.cnet.com/DriverMax/3000-18513_4-10572602.html?cdlPid=10896993
Posted on Feb 11, 2010
justinbill
  • 14 Answers
SOURCE: i need an audio device for my dell desktop optiplex gx520 install
you can go to dells website and click support drivers and downloads type in the service tag of the machine (its 7 letters and nubers found on CPU Ex: BF14FJ1) and based on the service tag the correct audio drivers should be displayed for you to download.
Posted on Feb 24, 2010
No sound device and yellow question mark by multimedia audio controller
Kristilyn,
You will need to download and reinstall the sound drivers into the system or use the Dell Drivers disk that was shipped with your computer to install. You can download the driver from the link below.
Dell Optiplex GX520 Audio Driver
http://dell.to/17lTTIk
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Aug 24, 2013 | Dell OptiPlex GX520 PC Desktop
Sound not play
if you're not getting any sound from your optiplex it means either your sound card is bad or the driver is missing or corrupted. You should change the sound card if the first is the case or update the driver if the later is the case. I strongly believe that it's the driver, do that first and if it doesn't work, change the sound card.
Hope this helps
pls vote this
Jul 04, 2011 | Dell OptiPlex GX620 PC Desktop
I need an audio device for my dell desktop optiplex gx520 install
if u cant install the sound driver just buy a USB sound adaptor and connect it to the USB port and connect the speaker sound jack to the sound port in that....u will have sound....also keep in mind that u " may" have to disable onboard sound in BIOS
get it in Ebay or goole it to locate a place near u
Feb 24, 2010 | Dell OptiPlex GX520 PC Desktop
I have no sound on my dell optiplex gx280. it tells me soundcard has been uninstalled/removed, or is being used by another programme.the latter is not the case.any suggestions.i only bought it 2nd hand,...
My first thought is to check if the card has become lose from the slot. To check that you will need to open the case safely (make sure to wear an anti-static wrist strap or ground yourself any time you move). Unplug your computer from all of the external devices and power as well.
These directions assume your card is not screwed into the back of the case (in which case either the slot is not getting enough power or the card is bad).
Pull the sound card out and place it in the slot (or, preferably, another open slot of the same type). Push down evenly on the entire card (sometimes you'll need to press on the front and then the back of the card until it is fully seated).
Close the case and plug in your external devices (at least power, mouse, keyboard and speakers) and test if the device is found.
I'm also assuming you have a sound card and not on-board audio. If at some time a sound card was added and the on-board audio was disabled, you may be able to re-enable the on-board audio after removing the sound card drivers. If the reseating of the card doesn't work, I'd try a new sound card.
I hope this helps.
Dec 10, 2009 | Dell OptiPlex GX280 PC Desktop
No sound and audio device
Download and re-install audio driver from dell website.
It should fix the problem.
May 16, 2009 | Dell OptiPlex GX520 PC Desktop
Can anyone tell me how to uninstall ethernet card in dell optiplex 320? I also need to know where to download and install the ethernet card. I can't go to ipconfig and see my ip address. The tech sup...
The ethernet card on the Dell Optiplex 320 is integrated into the motherboard and can not be physically removed. However, a new ethernet card could still be installed into one of the available PCI slots and can be purchased at just about any computer parts retailer.
Before you jump to replacing the card I would recommend trying a few things yourself to fix the card. Here are some suggestions:
One thing to try is disabling and then re-enabling the device through the device manager.
Another thing to try, go to the command prompt where you did the ipconfig, and type
IPCONFIG /release
then type
IPCONFIG /Renew
Those two commands have fixed many "dead" ethernet cards.
If those commands don't work and fix your problem I recommend giving this utility a try:
WinSock XP Fix
Does the computer recognize that there is an ethernet card in the system? Have you had any viruses or spyware/malware on the machine recently?
Mar 17, 2009 | Dell OptiPlex GX260 PC Desktop
Dell optiplex gx270 soiund device
MY OPTILEX GX270 AUDIO DRIVER NOT INSTALL WINDOWS XP.
I FORGET MY SOUND DRIVER NAME.
KINDLY SOLVE THIS PROBLEM.
Feb 01, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
Alun Cox
