Question about Oregon Scientific THGR122NX Wireless Temperature and Humidity Sensor
Thgr122nx Displays ll.l
Press program time, displays LL or CL will only start after pressing delay, runs a time then switches off
You need to post the model number of your dishwasher. Cannot find error code meanings without knowing the brand and model number.
Jan 01, 2015 | Dishwashers
Screen stays black after boot up
Use Recovery Console:
When a Windows XP boot problem is severe, you'll need to usea more drastic approach. The Windows XP CD is bootable and will provide youwith access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROMdrive on the problem system and press [Ctrl][Alt][Delete] to reboot thecomputer. Once the system begins booting from the CD, simply follow the promptsthat will allow the loading of the basic files needed to run Setup. When yousee the Welcome To Setup screen, press R to start the Recovery Console.
You'll then see a Recovery Console menu. It displays the foldercontaining the operating system's files and prompts you to choose the operatingsystem you want to log on to. Just press the menu number on the keyboard, andyou'll be prompted to enter the Administrator's password. You'll then findyourself at the main Recovery Console prompt.
Use system utility software like RegInOut after restarting windows.
Jan 01, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Will not boot up
Try with Recovery Console:
After restarting windows use a system utility software like RegInOut.
Dec 25, 2011 | Acer Aspire One Netbook 8.9" Notebook
How do I install my Win XP whn I have changed my harddisk ?
plz follow the steps...
1. Insert windows xp bootable cd into the drive
2. Power on the machine
3. When the logo displays, press F12 to show the boot menu
4. Select the CD/DVD
5. System will start the job
6. After showing Setup is starting windows, it'll shows the install option
7. Press ENTER
8. It'll show the drive but the drive is not partitioned
9. You can easily understand by reading the instructions
10. While creating it'll ask for drive space
11. Put 50000
12. Press ENTER
13. It'll ask for type of file system that you have needed, select the 1st one (Quick using NTFS)
14. It'll ask 4 format the specific drive. for that you have to press 'F'
15. It'll format and copy the needed files
16. System will restart. After restarting it'll start the job. plz wait.....!!! (system restart many times to complete its job)
17. While working it'll ask for the product key, time, etc.
18. Sit infront relax and give the needed information that you can understand easily
thanks & regards
Anas K A
May 28, 2011 | Fujitsu Lifebook T1010 Tablet PC
Controls won't work. Displays message: E0 -F2-
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 20, 2010 | KitchenAid KERC607 Electric Kitchen Range
It always displays a msg "memory is full "
Hello i hope u 'll be fine.... thanks for using fixya
  • Usually this problem 'll be occur due to full storage of memory, Every device needs some extra memory to run
  • To solve the problem you have to delete your some useless data of your mobile and u have to make some free memory
I hope this solution will work and helpful 4 u. Best of luck
Please do rate if if it is helpful
THANKS
Feb 10, 2010 | Nokia N72 Cellular Phone
Maytag neptune tl displays LL and stops during the rinse cycle
Sorry chukenne,
Having not experienced this issue on my FAV6800AWW I missed this error code in the manual is that your machine type? Error code “LL” is documented in the troubleshooting part of the SM as Large Load detected. Does this happen with all wash load sizes? I would go into Service Mode and step thru and document Diag codes form page 17 of the SM and see if you find any recorded error conditions. I would be curious to see if error code block 16 indicates a fail condition. I'm thinking of a possible high motor torque condition detected that may have triggered the LL code just a WAG at this time. You may want to clear all error codes and start collecting from your next wash cycle but I would make a list of all codes before you clear them for reference of fail events of past wash cycles. I’m going to assume the LL code happened during a spin cycle. What caused you to drop the clutch out and re-lube/ Were you taking dc/UC errors in spin cycle? Rich
May 27, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Hard to find Cobra 29 Part #LL-2253YG
there are a whole bunch of channel displays on ebay that will work with your radio.
Jan 08, 2009 | Cobra 29 LTD CB Radio
Can't Connect Displayed
CAN’T CONNECT
1.Displays when one handset is on a call and the other handset presses PHONE.
2.Displays when base power is off and PHONE is pressed.You’ll
also hear a sad tone.
3.Displays when an out-of-range dial fails to connect.
RINGER OFF
The handset
THIS IS SECTION OF MANUAL. MAKE SURE THE OTHER HANDSET IS NOT ON. PRESS THE OFF KEY JUST IN CASE.
Jan 25, 2008 | Vtech ia5845 Twin Cordless Phone
Help
CAN’T CONNECT
1. Displays when one handset is on a call and the other handset presses PHONE.
2. Displays when base power is off and PHONE is pressed. You’ll
3. Displays when an out-of-range dial fails to connect.
MAKE SURE THE HANDSETS ARE FULLY CHARGED. MAKE SURE BOTH ARE TURNED OFF, OR NOT IN THE TALK MODE. CHECK THE BATTERY TO MAKE SURE IT IS IN SECURELY IF DROPPED IT COULD HAVE JARRED LOOSE.
Jan 20, 2008 | Vtech ia5845 Twin Cordless Phone
Oregon Scientific THGR122NX Wireless Temperature and Humidity Sensor Logo
50 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Lawrence Oravetz
Timllfixit
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
