Pinout for a dell d250ed-00 power supply - Computers & Internet
2 Suggested Answers
jonsnell4
  • 21530 Answers
SOURCE: laptop compaq hp 6910 power supply pinout
What do you mean?
Posted on May 08, 2016
Pinout for dell OptiPlex 3020 psu
Anonymous,
Unfortunately, Dell does not have any documentation to download available for the Optiplex 3020 power supply pin outs.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 12, 2015 | Dell Computers & Internet
Pin out for a dell PS-5201-8D2 power supply
Use caution, some older Dell machines used a non standard, proprietary pin-out on the 20 pin connector ALso the 6 pin is suspect. If you connect a regular ATX PSU, you will fry the MoBo. Look here
DELL ATX motherboard Power Supply pinout
Jan 23, 2013 | Dell (PS-5201-8D2) (PS52018D2) 200-Watt...
Will a NVIDIA GeForce gt 610 graphics processor work on a Dell Dimension 2400 PC Desktop
YES, Zian it will work....BUT,....................
1) It is a PCI graphics card, and uses a PCI expansion slot.
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2898922&CatId=319
The Dell Dimension 2400 Desktop PC's motherboard, has three long white PCI slots,
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm#1105465
http://www.ebay.com/itm/Dell-Dimension-2400-Desktop-Motherboard-System-Main-Board-F5949-K5148-G1548-/190750417467?pt=Motherboards&hash=item2c699c623b
http://en.wikipedia.org/wiki/Conventional_PCI
If one of those long white PCI slots is open, you can use a PCI graphics card.
Concerned that the graphics card uses DDR3 graphics memory, and your computer only uses DDR Sdram ram memory?
Don't be.
The graphics card has it's own processor (Graphics Processing Unit), and graphics memory.
It runs independent of the system resources; the Processor and Ram Memory.
http://en.wikipedia.org/wiki/GPU
The concern is the Power Supply.
Original power supply's maximum rated Wattage is either 200 Watts, or 250 Watts.
The above graphics card requires a minimum system requirement/power supply requirement; of 300 Watts.
I would recommend replacing the Power Supply.
(Especially with it's age, if it is still the same one)
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1389575&CatId=1078
ONE thing though..............
Watch the 20-pin ATX main power cable connector, and the wires in it. Be sure they are in the standard place setup.
Check the pinout, and color code of the wires,
1) Dell Dimension 2400 desktop computer, 20-pin ATX main power cable connector pinout,
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/techov.htm#1105612
2) STANDARD 20-pin ATX main cable connector pinout, and color code of wires; as set by JEDEC,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
[Be aware that the ATX main power cable, and connector, you get with a new power supply; such as the above, will have a 20 =4-pin ATX main power cable connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
Use the 20-pin connector, tie the 4-pin power cable up out of the way]
For a time period Dell was making the motherboard's main power cable connector - Proprietary.
Meaning they has that motherboard connector wire pinout changed.
Colors of wires were in a different place, than the standard setup by JEDEC.
Orange wires are 3.3 Volts (DC)
Red wires are 5 Volts (DC)
Yellow wires are 12 Volts (DC)
Black wires are Ground wires.
Guess what happens if a 12 Volt Yellow wire, is plugged into where a Black Ground wire is supposed to be?
ZZZZZZzzzzt! Motherboard fries, processor fries, ram memory fries, and graphics card. (If used)
Check the color code of the wires, in the 20-pin ATX main power cable's CONNECTOR, for the Dimension 2400's power supply.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 14, 2012 | Dell Dimension 2400 PC Desktop
Control panel connector pinout for Dell Dimension 1100
Well the official Dell manual can be found on their website here. I don't know if this helps or not, but I hope it does! :)
Feb 17, 2010 | Dell Computers & Internet
I just need the pin out for the power switch connector
This link will show you the pinout for a UNIVERSAL power supply but it does not applyto Dells or Compaqs...
http://pinouts.ru/Power/atxpower_pinout.shtml
Feb 12, 2010 | Tyan Trinity 400 S1854 Motherboard
Can you supply pinout for Dell AA23300 Power Supply ?
On the main plug there is a single green wire. Jumper the green wire to any black groung wire in the plug and the fan will start and you will have output.
Nov 03, 2009 | Dell AA23300 550W Power Supply (X0551)...
Need the schematic to plug in the power connectors
This link http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm
is a great page for the standard ATX pinout and related info.
WARNNING dell's and some other psu's have a different layout.
If you look onto the power supply box, you will see a modle like
ATX130p3, google this with "pinout".
Aug 07, 2009 | HP Compaq Evo w4000 PC Desktop
Dead Dell
It is likely the power supply has suffered damage, or has just plain failed. Dell did have problems with certain power supplies in models such as the GX270, probably others too.
Anyway, if you have a voltmeter, you can check for the presence of voltages. Modern computer power supplies have a standby and main sections. I'd guess the standby portion is dead, and if so, your computer won't turn on at all. Here is a site listing the pinout & voltage spec for a typical ATX power supply: http://pinouts.ru/Power/atxpower_pinout.shtml
Note the standby line- again, this voltage will be present anytime the computer is plugged in. The main section of the power supply comes on when the power button is pressed.
If you tech savvy, you could try repairing the power supply if not toasted severely. Otherwise, a standard universal replacement might fit the bill, or just call Dell for an exact unit.
Jun 13, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
