Question about Staples SPL826X (CrossCut) Shredder
Shredder clicks but doesnt move
Lights are on but gears dont move
Have electrical issues on a 2004 mazda 3.
I would check every single fuse in the car. Blown fuses can cause weird issues like this. While the initial issue with the mechanic does sound like an alarm problem....the rest does not unless the shop that installed it really butchered the job.
Jul 18, 2016 | 2004 Mazda 3
Why is my 04 cadillac cts turning on but when i switch gears the car doesnt move?
Automatic trans? Check your fluid, could be low. Check with engine warmed on and on a level surface, engine running.
Feb 05, 2015 | Cadillac Cars & Trucks
Shifter will not engage into any gears
if you mean the shifter won't move out of park, see if your brake lights work when you press the brake pedal. if they don't that's your problem. check fuse and brake light switch for broken wires or bad switch itself.
Dec 05, 2013 | 2002 Ford SVT Focus
I have a 1993 nissan pathfinder automatic transmission and it will not move in first gear.it willl move in all other gears,in drive it wont shift out of second unless i push the overdrive button,what
check ecu fuse.your problem could be vechicle speed sensor also. if you dont see any ecu check engine light fuse either blowed or bulb burned out.but if ecu not working vechicle wont shift correct.
Dec 08, 2012 | 1993 Nissan Pathfinder
1986 F350 6.9 automatic will not drive but goes into gears.
automatics do not change gears
the gears are constant mesh and the ratio changes ( gears) is achieved by bands and clutches
change the transmission oil , and have the bands and clutches adjusted
Nov 16, 2017 | 1986 Ford F 350
2000 Jimmy - starts but can't shift into gear - can't push button in
Check ALL the fuses !!! Does the brake lights work? if not,, the shift inter lock may be disabled ,,, if the lights work the interlock solenoid might be the culprit . You should be able to get in gear by turning the ignition switch off then turning to the first selection ,,don't turn it untill the dash lights come on ,,with the key in that position you should be able to shift the lever to put it in gear ,,,,dont move the key untill its in the correct gear
Mar 15, 2011 | GMC Jimmy Cars & Trucks
2005 Navigator cant get it out of park? Button on side of gear shift wont budge when I push it in to try to reverse or drive
Does the brake lights work? If so try turning key forward just a little but not so far as to turn on lights, Try to move shifter then, If it moves? The shift interlock has malfunctioned, You can use that procedure to drive the vehical, Just do that and put in neutral and start the select your gearing, That way you dont have to tow it to a repair shop.. If the brake lights do not work? Check the fuse to it, If its good replace the brake light switch
Jun 13, 2010 | 2005 Lincoln Navigator
2001 ford escort stuck in park lever won't move starts normally
If it wont move into gear,the safety switch is malfunctioning. You can take the plug out of the hole on the upper right side of the console just to the right of the gear shift lever. put a philips screwdriver in the hole and press down. this will manually release the gear shifter mechanism.
Feb 08, 2010 | 2001 Ford Escort ZX2
My car turns on but it wont shift into any gear
dear friend-your blinker light has nothing to do with your gearbox problem,i surgest you have a look at the hazard switch.regarding you gearbox problem i think we must start at the gear lever.make sure that when you press the button on the shift that it does dis-engage,then while having the shift in hand move the car forward and back wards,try to dis-engage,if not you will have to remove the sump and look at the meganism inside,it has a half moon operating the shaft that is connected to the lock meganism.
Jul 18, 2009 | 2001 Hyundai Tiburon
Suburban wont go into gear
check to see if your brake lights are working.there is a safety system that wont allow you to shift from park unless you push the brake pedal........most of these systems utilize the brake light switch for this........if your brake lights dont work it is most likely a blown fuse.
hope this helps....
Dec 01, 2008 | 2003 Chevrolet Suburban 1500
Staples SPL826X (CrossCut) Shredder Logo
90 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Steve P
Steve P
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
