Question about GE GFWH2400LWW Washer
No power Plug is working but no power at the washer - is it expensive to repair?
Power outage
Probably the timer. That is an expensive repair 100-150. Make sure the water is on. Try selecting hot and then try cold. If one works and the other does not then it may be a valve which will be about $50.
Mar 10, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Hi, we have a Bosch washer model WFK 2401, in which we just replaced the door latch assembly and drain pump, and now it seems the electrical panel is going out. Since yesterday, when we push the...
Check with the repair man but I bet he didnt plug the panel back in all the way when he repaired it,maybe wanting another call. check it out
Feb 15, 2011 | Bosch WFK 2401
So I found this power washer for sale. The seller claims that the washer generates a good stream of water, not just full power. He also mentions that after a few minutes the engine starts to bog down...
Don't buy a power that doesn't work.
There are many expensive parts on a power washer. If it was cheap and simple to fix, the seller would fix it and the washer would not be for sale.
Would you buy a car that doesn't work? Especially one with a bad transmission? The power washer pump is like the 'transmission' > the pump is expensive to replace, and the replacement pump may not even be available.
Oct 18, 2010 | Garden
F1 error at start and either at 21 minutes or 19 minute mark during cycle. I have to push restart and start several times to get machine to work.
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#%^
Aug 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 keep coming up have to power off a few time to get to work
Washer shuts down showing F1. after 4 or 5 tries washer continues to work but clothes are very clean
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^#$
Jun 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Same problem as other customers, F1 comes on and washers STOPS and beeps. Looking to set up a repair appt.
Jun 16, 2010 | Whirlpool WTW6400SW Cabrio Washer
Every time I start the machine the f1 error comes up within a few seconds. have to press pause & start about 3 times & it will finally start to work. have to do this several times during the entire...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^@#$%
Jun 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 appeared on my display for cabrio automatic washer , and machine did not work. I tried uplugging unit over night and same thing occured the next morning
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@&@
Jul 13, 2009 | Whirlpool WTW6600S Top Load Washer
MAYTAG NEPTUNE FRONT LOAD WASHER MAH5500BWW
Central bearing and seal are damaged. Very expensive repair and very expensive parts. Maytag does not sell bearings separately, they're only available with the outer tub, which is $400-$500; Repair itself is another 2-3 hours of hard work. Do the math...
Jan 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
GE GFWH2400LWW Washer Logo
37 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
