Question about Garden
Changing blade in black and decker 3.5a jigsaw
Need to change blade
rowdy45176
  • 2176 Answers
SOURCE: I need to know how to change the blade on a Black
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in the model number 1710 and it will go to another page requesting either a breakdown or instruction manual, you have to use the manual for a type 4. They do not offer the type 2 as an online version. Hope this helps
Posted on Mar 30, 2009
  • 83 Answers
SOURCE: Looking for the Manual for a Black and Decker
Your going to need to contact a service center to get a manual. B&D own dewalt, that's why it's a dewalt site. Dewalt has a better name so they use it instead of B&D. Here is a listing of the service centers.
They might not stock parts and manuals for your tool anymore but it's worth a shot.
http://www.blackanddeckerservicenet.com/Support/FactoryOwnedLocations.aspx
Posted on Apr 02, 2009
SOURCE: Changing the blade in a bosch pst 65 pae corded jigsaw
Pull up the knob on the front at the top of the machine and push the yellow bit forward. Theoretically you should turn the knob anticlockwise three turns but it doesn't seem to make any difference on my one. Then take hold of the blade, ease it forward and turn through 90 degrees. You should then be able to pull it out. Replacement is, as they say in all the best manuals, a simple reversal of the procedure. When you are turning the knob clockwise this time it's supposed to click in place but my one doesn't do this and still seems to work.
Best of luck
Gavin
Posted on Apr 10, 2009
SOURCE: how to change blade on bosch jigsaw GST 80 PBE
I just bought a used one and faced the same problem. What I found in there is a set screw at the bottom of the long shaft. I used a long narrow flat head screw driver. It worked good, but I did have to acuate the trigger to get it the blade near the top of the stroke
Hope that helps.
AG
Porsgrunn Norway
Posted on Aug 15, 2009
rcalorisian
  • 313 Answers
SOURCE: Instructions for changing blades
I didn't find it under those numbers, but I didfind out it is or will be discontinued. I did find the manual that should help you with changing the blades, Here is the link to the manual:
I hope this helps, Let me know if it does or if you have any question..
Posted on Sep 11, 2009
What models of jigsaw blades are suitable for cutting wood using a Black & Decker DN31-H1 Jigsaw?
Blade can be had at any hardware store or home improvement store. There are a lot of wood cutting blades available depending on the hardness of the wood and how thick the material is
Nov 06, 2014 | Saws
Part that guides the blade is broken need a new replacement
Search online for black and decker parts using the model number (on the label on the jigsaw). But Black and Decker are manufactured to bot be very durable, its better and probably cheaper to replace it, with almost any other brand. If cost is an issue but a used high quality item on ebay, made by Makita, Hitachi, Bosch or Metabo. Even and old one of these is better than a black and decker.
Nov 01, 2013 | Black & Decker Scroll Jig Saw Blade
Change blade Black and Decker jigsaw 7568 Type 1
I had a heck of a time. The set screw was not anywhere I could acess it. Finally figured out that the motor had stopped in the 'up' position. Once I got it back down the set screw was right there.
Mar 06, 2013 | Black & Decker Scroll Jig Saw Blade
Hi I have a Black and Decker Jig Saw 7588 Type One that works fine but I can not find replacement blades for it here in San Diego, California. Where can I find the blades?
I have the blades and the 7588 jigsaw. thinking about selling on ebay. search for black & decker jigsaw w/ blades in next couple days if interested in buying saw with 6 blades. thankyou, makthriftsales
Jan 14, 2013 | Black & Decker Single Speed Jig Saw
How do i fit a blade on a black and decker jigsaw KS656PE
Sorry Gavin, but you have posted this solution word for word the same for a number of jigsaws. the KS656PE does not have a knob to pull or turn so you do not know this model and your suggestion is wrong.
I cannot advise a correct solution as the advice in the manual is wrong!
regards - Mark
Mar 15, 2011 | Black & Decker Black Decker 45amp Orbital...
How do you put a new blade into a Black & Decker JS4000 Type 1 jigsaw
There is a black plastic switch where the blade is slid into the jigsaw. The black plastic switch can be seen and accessed from the front of the jigsaw through the clear plastic sight guide...You pull the black switch toward the bottom of the jigsaw and it opens the space for the blade to slide into, when you release the switch it will close the space and lock the blade into place.
Hope this helps.
Mar 06, 2011 | Garden
How do i remove the blade on a black and decker U255S Jigsaw
either on the left or right side of the blade holder there will be a little lever to pull that will release the blade, pull on the blade at the same time you pull on this release
Jan 17, 2011 | Black & Decker Black Decker Orbital...
Black & Decker Blades
the blade jig saw does not stay in on black &decker js2500
Mar 07, 2010 | Black & Decker Scroll Jig Saw Blade
I do not know to use the black and decker jigsaw.
Draw the circle pattern on the wood where you need it. Drill a 1/2 or 3/8 inch hole inside the circle, near the circle line. Insert the jigsaw blade into the hole and start cutting, following the line.
If you have the scrolling feature on your saw, don't use it, lock the scroll.
Sep 20, 2009 | Black & Decker Saws
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
