Question about Dewalt Tools & Hardware - Others
Speed issues with orbital sander
Starts to die before switch is turned off
mikeymiddles
  • 58 Answers
SOURCE: Orbital sander flicking the sand paper off
You did not specify how the sanding discs are meant to be attached to your sander's backing pad.  My experience with this type of problem is material from the sanding process builds up on the backing pad and does not allow the sanding discs to adhere properly.  If you have a velcro type system, clean the hooks on the sander's backing bad by soaking the pad's face in a plate of paint thinner for 20 to 30 minutes then use a wire brush to remove the rest of the paint physically.    For adhesive pads clean the sander's backing pad surface with denatured alcohol.  Do not use isopropryl or rubbing alcohol as this may not be 100% alcohol and could contain a lubricant like glycerin.  When the sander's backing pad is completely dry and clean it will hold adhesive backed pads fine.    Flaky paint is best scraped off before sanding, use a wide putty knife or a paint scaper to remove large flakes before sanding.  This will minimize airborne dust and cleanup.    For best results with adhesives, always keep your surfaces  clean!    Good luck and happy sanding!  Michael Mittelsdorf
Posted on Jan 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: Makita 5010 will not work in random orbital mode
It sounds like the bearing in thee bottom plate is seizing. If you turn the pad by hand does the motor turn. It should be smooth. I would look at that. The bearing number for Makita is 211236-8 or if you can get a generic bearing it is 6002DDW. Let me know
Posted on Jan 12, 2009
rowdy45176
  • 2176 Answers
SOURCE: Hitachi SV13YB 5
You can go to Hitachipowertools.com and under products scroll down to find your sander. They also have a dealer locator that will find someone in your area. I looked at both the breakdown and manual for this tool and am concerned because it says pressure sensitive, but the literature states hook and loop, so you would have to specify the hook and loop. Let me know if you have any problems finding someone and I will try and help
Posted on Mar 23, 2009
comax
  • 154 Answers
SOURCE: Bosch 3107DVAS Random Orbital Sander not working.
You must replace the fan assembly. The part number is
2606610901
Hope this helps
Posted on May 05, 2009
  • 384 Answers
SOURCE: orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Posted on Jun 12, 2009
How do you change speed on mikita BO5030 orbit sander
If there is no adjustment on the trigger or a roller knob its not adjustable.
Aug 14, 2014 | Makita Bo5031k 5" Orbital Sander...
Ridgid random orbit sander will not turn on
Mine also, in the middle of a job and it just stopped, no warning , did not slow down or bog just quit.
Apr 26, 2014 | Ridgid R2601 5-Inch Random Orbit Sander
My 5" random orbit sander model 333 is spinning out of control. What do I do?
I may not have the whole picture, but all random orbits spin wildly if they are not pressed onto the wood a little. Do you mean it is not oscellating, but just spinning when it is on the wood? That would be an issue requiring cleaning or repair, otherwise, just don't turn it on until you have placed it on the wood to avoid marring.
Farmerbear:)
Sep 07, 2010 | Porter Cable Random Orbital Sander, 5"
Orbital sander doesnt orbit!
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
3725Bosch 5" random orbit sander, loss of power!!
The 3725 had an overlap winding problem in the armature allowing no full power under load, I replaced mine three times before getting a good one, best 5" on the market tho.
Jun 07, 2009 | Bosch 3725 Devs, 5" Random Orbit Sander,...
Porter Cable Random Orbital Sander rotates but does not "orbit"
Just solved my problem with Porter Cable 333 orbital sander which just groaned. I thought the worst. I carefully took it apart on the garage floor and immediately suspected it needed lubrication as the motor turned hard. I used my flexible long plastic tube lubrication and put some on the bottom bearing shaft the best I could. I worked it around and around. I began to feel it turning easier. I applied more oil and kept moving and it became completely free. I put a drop on the top bearing even though it was loose. I put it all back together and it works like new. Lesson: do not look for the worst when a tool quits. Suspect the culprit to be lack of lubrication!!!
May 20, 2009 | Porter Cable 332K Quicksand Random Orbit...
Putting Sanding paper on makita sander
A makita power planer is just what it says, a planer. It has blades that spin at high speed and remove a thin layer of wood with each pass. The orbital sanding sheets go on another tool called an orbital sander. Write back if you find the sander and can not figure out how the sheets go on it.
May 02, 2009 | Makita 9404 4'' x 24'' Belt Sander
Jan 11, 2009 | Makita Tools & Hardware - Others
7336 orbital sander
If you are talking about the actual sanding pad itself it should just pull of .If you are talking about the backing pad it should un screw
Sep 10, 2008 | Porter Cable 7336 6 Inch Variable Speed...
Tools & Hardware - Others Logo
22 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
