Question about Cell Phones
Disassemble and clean lg ls995 flex
I was I a motor vehicle accident phone got wet but did not get submerged I've edited a week and it'll show lg logo when plugged in but does not turn on
Fixe_You
  • 1800 Answers
SOURCE: LG Shine CU720 Flex cable replacement
well take apart the lcd part and the keypad part and strat connecting the flex cable.
use this trick:
use ur digital camera to take shots for every step u performed so u not getiing lost after taking the phone one part.
aslo while repalcing the ld put the new on it place!!!
Posted on Feb 10, 2009
SOURCE: Lg Prada KE850 will not turn on, just has the white prada logo
**** les gard jais mon lg ke850 qui salume par momen
Posted on May 05, 2009
  • 124 Answers
SOURCE: LG Rumor 2 won't get past the lg logo on startup
this is a software problem !!! change the software fo your mobile in the nearest outlet
Posted on Jul 17, 2009
mattdehat
  • 713 Answers
SOURCE: my lg kp501 just shows lg logo
do a firmware upgrade
Posted on Sep 16, 2009
fathitkf
  • 1871 Answers
SOURCE: Spilled vodka on my phone.
The next solution is about water damage , just try it for your problem :
This works on most mini electronic devices like cellular phones and degital cameras etc . it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY .
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
rate if useful please !
Posted on Jan 21, 2010
My iPhone got wet
Have you tried putting you phone in a bag of uncooked rice? I've heard the rice will pull the moisture out of the phone.
Oct 02, 2012 | Apple iPhone4 4G iPhone 4
How to clean them
Clean your air tower fan by using small paint brush and wet rag(s). Turn off power and unplug, then open the fan by using screw driver either flat or crossed type. Eliminate dust and dirt using paint brush and rub it with wet rags. When disassembling put screws in box and be observant so that you'll able to assemble it later. Do not wipe motor with wet rags only the propeller, front back cover and so on.
Good luck.
Jul 17, 2011 | Lasko 48" Xtra Air Tower Fan with Air...
My Lg Xenon GR500 cell phone`s touch screen is black it still works, but you cannot see anything!
Hi, Lg Xenon GR500 cell phone`s touch screen is black it still works.these are usually caused by the flex of the phone.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
Hope it helps.
Thanks for using fixya...
Jun 16, 2011 | LG Xenon GR500 Cell Phone
Hi all the buttons on my LG Prada KF900 mobile have stopped working. The touch buttons are fine its just the actual "real" buttons ie. the two on the front and all down the sides. Any idea whats...
Hi, no need to get a new phone, It can be fixed.There is a common fault for all LG Prada KF900 cell phones. there is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction. You will need to replace the thread like object which is the flex inside the phone for the keys to function again.
Hope it helps.
May 24, 2011 | LG Prada KF900 Cell Phone
How do I open my lg vx8700 to replace the ribbon connector? Should it be replaced or can it be repaired or cleaned?
It cannot be cleaned or repaired, the flex cable must be replaced. This is a very difficult task as the entire phone needs to be disassembled. There are many small parts to deal with not to mention your new flex cable is very fragile and can be easily damaged in the installation process. Its best to have a tech handle this one unless you are very brave....... lol
Jan 11, 2011 | LG VX-8700 Cellular Phone
LG display is completly black, however the phone works
The problem is either in the the flex ribbon connector, connector terminals or LCD itself. Disassemble the unit then check the flex ribbon connector for any crack or damage. If no apparent damage is found, clean both the flex terminals and the connector terminals. Resoldering the connector terminals is also suggested. If no result, LCD is damaged, replace it.
Oct 18, 2009 | LG Shine CU720 Cellular Phone
use this trick:
Jan 30, 2009 | LG Shine CU720 Cellular Phone
Error message: unapproved battery
Water is very bad for these devices, obviously. The battery was damaged when it got wet. Take your phone in with you and get a new battery. Fortunately it sounds like your phone will be ok.
Jan 11, 2009 | LG Chocolate Clamshell VX8600 Cellular...
Battery is required to charge......got this message on my LG Muziq just out of the blue, now what can I do?
First I would try going to the sprint store and try a different battery. If it works fine with that, buy it. If you get the same error with a new battery, try a different charger. If you still get the same error with a new battery and charger, disassemble the back of the phone with a small phillips screwdriver and remove the main board. Once the board is out, clean it with rubbing alcohol (preferrably 91% rubbing alcohol) and a toothbrush, especially around the charging port and the battery terminals. If it has gotten wet, you should see the corrosion when you open it up.
Be very careful unplugging the flex connections. A small tear or bent pin could cause costly damage to the phone.
Aug 21, 2008 | LG Cell Phones
I850 stopped responding
Your Code lug may be corrupt you have to ake your unit to a serivce center for repair sorry
Nov 27, 2007 | Motorola Mobility i850 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
