Question about Sakar-Vivitar VIVITAR Vivitar ViviCam F128 14.1 Megapixel Compact Camera - Black. 14.1MP HD DIGICAM/2.7SCRN LICORICEBLK. 2.7" LCD - Electronic IS - 4416 x 3312 Image - 1280 x 720 Video - HD Movie Mode
Vivicam 128 F no shutter
Vivicam 128 F, does it have any lens protection? I put the batteries in correctly and turned it on, went through the setup. I then took a picture, viewed the picture and turned the camera off. The glass lens was still cover, unprotected from dust, dirt, etc. is this normal for this camera. I called the sakar number, gave the model #, and was told to remove batteries and reinsert to activate lens protection???Still no closure of lens glass. Does the Vivicam 128 F have ability to close lens?
My Vivitar Vivicam 5388 lens will not move or shutter operate
Hi cda_graham
Usually it is a flat battery which causes this problem. You have to put in new battery once again and try.
Good luck
Oct 06, 2009 | Vivitar Cameras
Protective lense shutter is stuck partially closed, causing black corners in the photos. How do I fix this, or remove the shutter completely?
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But for the A610, you might want to extend your zoom all the way out before removing the camera's batteries. Note that the A610 has four shutter leaves instead of two, so pay particular attention how they're assembled if you remove the lens ring. Also you'll be applying the ring loosening rubbing alcohol around the barrel's perimeter instead of the front as shown in the procedures. One other thing, try not to get any alcohol on the lens itself:
Good luck, and remember to do this only as a very last resort (try the other listed procedures first). Oh, and if you do decide to try the repair, please post how it went.
May 28, 2009 | Canon PowerShot A610 Digital Camera
The shutter is stuck on my vivitar 3746 and won't turn on or respond in any way. what can i do?
This always happens on mine when the batteries are low or taking them out while lens is extended. What I had to do was take it apart and manually wind back in the lens via the gears that extend it. Hope this helps. Otherwise the camera is rendered useless.
Mar 06, 2009 | Vivitar ViviCam 3746 Digital Camera
Protect mode on vivitar vivicam 5386
hi there
this is the disc that you use in your camera correct, put the disc back into camera if so go to your camera setting like if you were going to review your pics.and go to the place where you went to lock the pictures press menu find protect again hit function settings hit select it will bring that picture back up again click function again and this will unlock it. this works for my cannon but it goes something like that hope this works for you its hard to explain but i had the camera in hand its easier do it. i just did it with my sons hope i didnt confuse u
Jan 19, 2009 | Vivitar ViviCam 5386 Digital Camera
Vivitar ViviCam 3765
I found a plastic top which fits and acts as a lens cap.
Jul 14, 2008 | Vivitar ViviCam 35 Digital Camera
Shutter will not close!
very small dust particals are the reason of this problem.I m suggesting an idea but apply it on your own risk.Keep camera in off position then slightly strick with ur fingernale around the lens ring evenly.This can make the lens shutter contrct.Once the shutter closed,clean gently with a painting brush over the edges where shutter slides this for several times so that any hard dust partical causing may not insert anything inside.
Aug 12, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
When i turn camera on shutter closes and lens goes inside, and other way round...
Try the Sony web site technical help. but I feel that there is a main board fault developed here- perhaps time for a new camera try the tech help first though
May 28, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Vivitar vivicam 5386
I have had that problem too. All I had to do is change the battery. But don't mix match batteries good luck.
Mar 03, 2007 | Vivitar ViviCam 5385 Digital Camera
Sakar-Vivitar VIVITAR Vivitar ViviCam F128 14.1 Megapixel Compact Camera - Black. 14.1MP HD DIGICAM/2.7SCRN LICORICEBLK. 2.7" LCD - Electronic IS - 4416 x 3312 Image - 1280 x 720 Video - HD Movie Mode Logo
23 people viewed this question
Top Sakar-Vivitar Cameras Experts
Are you a Sakar-Vivitar Camera Expert? Answer questions, earn points and help others
