Question about Belling Solitaire G755 Gas Kitchen Range
Oven flame to high - Belling Solitaire G755 Gas Kitchen Range
FLAMES TO HIGH IN OVEN G E GAS RANGE
Are you on propane (LPG) or natural gas? If on propane, then the oven has not been converted to propane properly.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 10, 2014 | Kitchen Ranges
Oven flame too high
This is cars and trucks but i will endevour to give some sort of answer ,the flame being to high could be caused by a faulty regulator if used from a gas bottle or again the regulator on the gas meter if mains gas ,alternativly the jet that feed the burner has a enlarged hole in the part that you can see with the flames ,well at the bottom of that a jet that injects the gas into the burner which also has air holes in the bottom to mix the gas so look at the burner first and see what you can see in the way of any air holes being blocked with dried fat
Mar 19, 2012 | Cars & Trucks
Oven flame to high
You must adjust the orifice on the safety valve with a 1/2 inch wrench.
Tighten it.
Jul 04, 2009 | Ovens
My Viking gas oven is slow to heat?
very likely the thermstat is defective, most likely the oven temperature proble
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
Oven lights on low flame but will not come up on high flame .cannon chester cooker.suspect by pass is not working. Do I need control knob/thermostat with the phial. Thanking you.
all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
Apr 26, 2009 | Ovens
High flames in oven
Flame saftey device control valve stuck in open position that why main gas is coming other wise flame should be max 2cm long after flame saftey device heat up and bellow expand and main valve should open
Jul 21, 2008 | Frigidaire FGB24S5A Gas Single Oven
High flames
you need to convert your oven!!!! sounds like you have LP or tank gas, nad your oven is set for naturla gas. theres instructions on how to convert in installation guide, not hard !!!!!
Jan 16, 2008 | Frigidaire FEF376 Electric Kitchen Range
Lp flames to top of oven
You need to tighten down the orifice spud for the bake burner. Remove drawer in bottom of oven. Look for bottom of burner tube, where the shutter adjustment is. Right below it is the orifice spud. Usually a goldish color. Take 1/2 inch open end wrench and tighten until it stops. Do-not overtighten! Try it now. If flames are still to high, tighten a little more. Repeat if needed.
Nov 18, 2007 | Kitchen Ranges
My gas oven flame
BLOCKED JET MAYBE CAUSED BY FOOD SPILLAGE OR BLOCK IN PIPE TO JET
May 28, 2007 | Parkinson Cowan SG320 Gas Kitchen Range
Belling Solitaire G755 Gas Kitchen Range Logo
20 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
