Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Replaced the 1amp fuse and washer still is not working
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: Maytag stacked washer/dryer model no. LSE7806ACE;
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the door switch assembly, if the door switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 24, 2011
Would a 2 amp fuse instead of a 1amp fuse cause the breaker to kick off
Most likely
Are you hoping to damage the wiring or have a fire?
You need to google what a fuse is & why you never
replace with a larger one
That question hasn't been around since the 1950's
People have educated themselves some since then
Aug 28, 2013 | Dryers
I'm trying to connect my 1amp red wire for my
if you want the quick easier way, pull one of the light fuses and wrap the wire around one of the blades of the fuse, then reinsert it.
One side will be constant power, the other will be only when you turn on the switch for lights.
The pic shows you the tail lights. (fuse #9)
You can jump in there and it's worth a shot.
Jan 19, 2013 | Cars & Trucks
Microsoft Cpa09-010a Ac Adapter Xbox360 Slim 135w stopped working
if your volt is 220v. so you can use fuse on AC line 600mA to under 1Amp.
DC line fuse is under 12Amp. clean any power cable port & use perfect gas.
May 28, 2012 | Microsoft Cpa09-010a Ac Adapter Xbox360...
P25 Koolatron fuse ahs to be replaced. Can't read AMP on old one. What AMP do I need to replace it? Nothing on thi son Kollatron's website, incredible!
If fuse blows, it normally means there is a fault. To briefly recap, compressor is about 2 amps, fans x2 is approx. 1 amp. and light/other 1amp. Possibly a 5 to 6 amp fuse. If it trips again, have the compressor or fans checked.
Aug 05, 2010 | Koolatron (2526435) Beverage Cooler
Just stopped working. No LED. Changes the Lamp no fix! ANy clues
The first generation of the IN72 / IN74 / IN76 projectors had a power supply problem where a fuse on the P/S was under-rated. The 1amp fuse was subsequently replaced with a 2.5amp fuse to correct the problem. The reworked units have heat-shrink tubing over the fuses whereas the older 1amp fuses are bare. The fuse is located under the heatsink, about center of the board.
Feb 14, 2010 | InFocus Play Big IN76 Multimedia Projector
Completely dead is their a fuse
Yes it does have a fuse. This will require you to remove the 8 screws from the metal housing. Then remove the housing. The fuse is located toward the back of the unit on the right hand side when looking down. It is a small 1amp, 250 V fast acting fuse, which can be found at Radio Shack if it is blown.
That said, there is no guarentee that this will fix your issue. I replaced the blown fuse and the unit still does not work. You maybe lucky and that solve the problem.
Jan 06, 2009 | Cyberhome CH-DVD 300 DVD Player
Lighter plug
First if you still have the old "lighter plug" unscrew the ribbed end cap of the cigarette lighter adapter and check to see what size the fuse is. If you don’t have it anymore it originally took a 1amp fuse. Do Not use anything bigger then a 1amp fuse....You can pick them up at your local electronics store like RadioShack. In fact they will have a cigarette lighter adapter for you just remember to take in your Cobra ESD 6000 Radar Detector...I hope this helps...Let me know... cbinny1
Oct 20, 2008 | ESD 6000 Radar Detector
Maytag stackable w/d
Yes, it is inside the front washer lower front panel. Turn off poawer to unit and change w/ 1Amp 250V (regular of slow-blow). Then try only opening washer lid door with full dial pushed in (that would be the 'off' position. Only open/close lid w/ dial in off position. If washer works normally, may have a temp solution. Mine started this way, but ultimately the double relayed door lid switch was going bad and I had to replace it. Instructions/pictures below. Good Luck
AT702
Jan 27, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
