Question about Health & Beauty
What year was my dovo made in
Its a 40 DOVO FRITZ BRACHT SOLINGEN GERMANY Straight razor
My E300 runs for 15 minutes get's slow rests then runs again what wrong???
it will run slow for 40 mins at a slow speed, after 15 mins of running fast, the batteries get too hot
Apr 11, 2016 | Razor E300s Electric Scooter With Seat
Dull razor blades after moisturizing stripe wears off
Expensive replaceable cartridges are only made to offer 4-6 "good" shaves for most people. Sorry - that's the deal. You can strop cartridges (in on direction only) on denim and pick up maybe a dozen more - search youtube for examples. I finally gave up on carts and moved to a straight razor; a razor or two will last for a lifetime with good care. There IS a learning curve for safe use and maintenance procedures. Find a straight razor forum if you want great shaves and good advice on what to buy, what not to buy and how to be safe.
Double edged safety razors are also a very good alternative for better, smoother shaves and WAY less expensive blades. Same advice - find a razor forum to save money, buy right and avoid nicks.
Apr 16, 2014 | Health & Beauty
Is it necessary to hone a straight razor?
All razors lose their edge over time even with daily stropping. Honing reestablishes the fine edge of the razor by removing some of the medal some of the metal from the razor. Honing is a necessity when it comes to razors.
Feb 06, 2013 | Health & Beauty
What is the balance of a straight razor referring to?
The balance of the straight razor refers to the relative weight and length of the blade as compared with the handle. A straight razor is properly balanced when the weight of the blade is equal to that of the handle.
What should I consider when Im buying a straight razor?
The key things you need to consider when you buy a straight razor are its balance, its temper, the size of the blade, its grind, the finish of the razor and its style.
What are the advantages of straight razors over modern razors?
The one big advantage of the straight razor is that if you take care of it properly it can last for a long time unlike modern razors which you simply throw away after a few shaves when they come too dull to use.
Whats a straight razor?
A straight razor is a shaving razor constructed of a long steel blade attached to a handle by means of a pivot. A straight razor is a classic shaving method and nowadays it is less commonly used since the invention of the safety razors.
I have a Sabre Solingen #111 fixed blade knife that is missing one or more pieces from the pommel portion that keeps the knife together and components tight. I am looking for the replacement parts.
I found a Sabre Solingen 111 knife in the woods in 1963. I've kept it over the years and just wondering how old it is ? The flip side of the fixed blade says American Knife Co. Germany. I've never had a knife keep a sharp edge like this one. It's a beauty for sure. Thanks if you can help. Bill
Jan 10, 2011 | Garden
My midland allen 78+ uk channel has changed to am it should be fm
I Italy 40 Ch AM/FM 4 Watts I2 Italy 34 Ch AM/FM 4 Watts D Germany 80 Ch FM 4Watts/ 12 Ch Am 1 Watt D2 Germany 40 Ch FM 4 Watts/ 12 Ch AM 1 Watt D3 Germany 80 Ch FM 4 Watts/ 40 Ch AM 1 Watt EU Europe 40 Ch FM 4 Watts / 40 Ch AM 1Watt EC CEPT 40 Ch FM 4 Watts E Spain 40 Ch AM/FM 4 Watts F France 40 Ch FM 4 Watts / 40 Ch AM 1 Watt UKE UK 40 Ch Fm 4 Watts UK frequencies UKC UK 40 Ch Fm 4 Watts CEPT frequencies PL Poland 40 Ch FM/AM 4 Watts midland alan 78 multi plus frequencies
Jun 06, 2009 | Midland 1001Z 40-Channels Base CB Radio
Health & Beauty Logo
73 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
