Question about Car Audio & Video
Will not turn on
I changed the auto shut off to zero and i can not turn it back on
  • 20 Answers
Try unpluging the battery for about 15 seconds then plug it back in, most electronics go back to factory settings when there is no power going to it
Posted on Jun 23, 2009
Why does me Cuisinart coffee maker shut its self off immediately after brewing
You seem to have the AUTO OFF feature programmed to zero hours. You can set it up to 4 hours in 1-hour increments. Once you have set AUTO OFF to something greater than zero, you can
restart the timing cycle by cycling the on-off switch off then back on.
Jan 04, 2015 | Cuisinart DCC-1200 Coffee Maker
How do I reprogram my platinum Keurig so it does not shut off
With unit powered on, Select Menu button, scroll down, and turn "auto off" to off selection. Cup size is selected after you put K Cup in. The display should flash on a default (1 of 5) cup sizes. You can manually change to the size you want. Alternatively, you can select the Menu button and change the default cup size (same process as stated above).
Nov 25, 2013 | Keurig Platinum B70 Coffee Maker
Oil pressure guage stays at 40 psi on ign/engine shut down, but drops to 0 psi when ign is turned back on, and then on starting of engine operates normally... What's up ???
the oil pressure gauge only gets a reading when the engine is runningas the oil is being curculated. when you shut the vehicle off it should go back to zero and be there until the vehicle cranks back up. i hope this helps
Feb 05, 2011 | 2002 GMC Sierra 1500
Compressor motor shuts off but does not turn back on
it sounds like you have a bad temperature control thermostat. the contacts are probably dirty or loaded with carbon. replace it.
Mar 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
1993 Honda Accord-shuts off while driving/won't start up
I had the same problem. My car would shut off without any warning, I changed my Main Relay located under the dash, right below the change slot on the left hand side. I have not had a problem since. The price at Napa Auto parts runs about $68.00. This should fix your problem.
Oct 08, 2008 | 1993 Honda Accord
Auto attendant
I was poking around on the web and found your question. I designed the SI-460 a few years back. Casio, sadly, shut down their phone division.
I can e-mail you the owners manual (PDF) if you need it.Anyway, in case you haven't figured it out:
To turn off the auto attendant:
Press the PROGRAM key.
the display will indicate:
PLEASE SELECT
PNON ANSW OTHER
Press the key under ANSW
The display will indicate:
AUTO ATTND: ON
BACK CHANGE NEXT
Press the key under CHANGE
AUTO ATTND:OFF
BACK CHANGE NEXT
Press the program key to end the process.
Good Luck.
Joseph Quevedo
joequevedo@charter.net
Jan 17, 2008 | Casio SI-460 Corded Phone
Why does it turns itself off?
it's locked. Change the switch on the back. (supposed to use to keep from accidentally changing songs etc.)
May 01, 2006 | Apple iPod nano
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
