Question about HP Officejet 6600 e-All-in-One - multifunction fax / copier / printer / scanner color
HP Officejet 6600 encoder strip - HP Officejet 6600 e-All-in-One - multifunction fax / copier / printer / scanner color
aomcopier
  • 22 Answers
SOURCE: encoder strip
These can be difficult. Is the spring still on or do you still have it? Do you have a spring hook? If you don't, go to electronics store and use it to pop the strip back on the spring. www.tonerovernight.com
Posted on Mar 29, 2007
Inkworks
  • 87 Answers
SOURCE: FAO Inkworks Guru...
$30 shipped out priority mail. Send funds to paypal account inkworksinc@charter.net. Please provide mailing address when making payment.
Inkworks
866-381-0541
Posted on Dec 02, 2008
freetek
  • 5568 Answers
SOURCE: I displaced the encoder strip on an hp Photosmart
Typically, HPs have one fixed hook for the hole at the end and for the other end, a spring steel piece with a hook. Take a good look at the carriage; it will have a vertical slot, located toward the innermost part of it through which he strip needs to pass. Either take the strip (clean it gently while it's out), push it through the carriage while it is centered and look along its possible path for the hook arrangements. I don't know your particular printer but some of them require removal of the case to access those points. If you have a longish tweezer, you may be able to fish it into place (using a flashlight) anyhow. Be sure to fasten the spring-end first since the fixed end will not give and you risk tearing the mounting hole otherwise.
Posted on Apr 22, 2009
  • 6 Answers
SOURCE: My Hp z6100 carriage jamms
Maybe u need another encoder strip If u dammaged the strip while cleaning.I've cleaned mine only once with water and a soft a wet clout.Cleaning must be verry gently
Posted on Aug 19, 2011
vinay229229
  • 1121 Answers
SOURCE: I have a HP Z6100, and I got many times error 86:01 possible paperjam, after changing encoder strip and encoder sensor, carriage PCB. I still have 86:01 error, after Scan Axis in maintenance mode, the
Observe when 86:10 error appearing? after intializing the carriage or immediately after powering on?
# If immediately error appearing do the below discussed activity
# after intializing if error appearing check trailing cable,service station wipers & cappings,cutter position, cutter movement & lubrication on rail.
Detatch power cable & data cable,remove right door, pull out carriage assembly from service station area (if its locked by service station manually unlock it). Remove cable connections, screws & take out service station from the printer.Place the service station out side(ensure that cables has to fix properly) connect the cables,switch on the machine, check for the error..
if error is not appearing: check the service station, found any damage replace it or shoot the problem.fix it back..
*even error is appearing: Remove carriage belt from the pully..check carriage movement, if found any hardness/obstruction? shoot the problem.
Finaly: check trailing cable( while carraige movement some tracks may lose their continuty)
Power supply.. ( check voltages)
Need your feedback for further help.. vinay229229@yahoo.co.in
Posted on Apr 11, 2012
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
Part number cbo218007b-15
That part number is for the Optical Encoder Strip that the printer uses to tell how far the print heads have moved. I just posted a step by step guide that I hope will help you reinstall the strip in t=your printer. You can get it here.
http://www.ccl-la.com/blog/index.php/reinstalling-the-optical-encoder-strip-on-a-hp-officejet-8600-printer/
We do printer repairs in our shop and have seen this happen many times on different models of inkjet printers.
I hope this helps you.
BuddyMc
Feb 07, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Printer cuts off print at top of page in spite of over 1" margin and every 3rd or fourth line of print in document is very weak (not much ink)
Hello
Well are you using the external ink-system? even if you are not the disk encoder and the encoder strip needs to be cleaned. Encoder Strip is the plastic strip connecting from left to right inside the printer near the belt. In the same type of plastic there is an Disk encoder on the left side of the printer you can find it if you open the printer only.
Jul 23, 2011 | HP OfficeJet Pro k550 Printer
Cannot align cartridge
ok, now clean the encoder strip with clean cotton. encoder strip found and the back of the printer ink assembly look like a plain white plastic. wipe that till it clean.
Apr 14, 2010 | HP OfficeJet 6110 All-In-One InkJet...
White lines across print
If you lay the print on the exit tray face up and open the cover. Look on the encoder strip, the clear plastic strip behind the carriage, you should see an ink or grease spot right above where the bad spot on the page is. Wipe the encoder strip with Q-tip or wiper with alcohol. Prints should look better.
Jan 08, 2010 | HP OfficeJet Pro k550 Printer
Prtiner Cartridge Housing collides with Rail Stop
this is due to the weak enoder strip.printer reads the encoder to move accordingly.if the strip is turned faulty it will not move properly resuling in istorted print and colliingthe pinter walls.get encoder replaced. it will cost 10 dollars plus technicians service charge.common problem nothing to worry.
Dec 26, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Prints in staggered columns
What you describe is typically caused by ink aerosol building up on the encoder strip, a thin band of plastic that the printer uses to keep track of its location.
You can gently clean the encoder strip as shown at HP's website here. Be sure to heed to cautions and notes. Do not use any solvents other than water and be gentle to avoid damaging the encoder.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 24, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Print problem
If your machines are like other 7310's and 7410's that we have serviced, the inside of it is probably coated in ink spray. Over time this spray will build up on the encoder strip and cause print image defects. You can just clean the encoder strip for a temporary fix but I would have in completely torn down to the metal frame and cleaned good. We charge $85 for this type of cleaning which cures what ails most of this line of printers.
Inkworks
866-381-0541
Apr 28, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hp g85 all in one
The "plastic strip" is the position encoder of the print head, it holds itself in place by two latches, one is fixed and the other is flexible, you have to put the encoder in the flexible latch first by holding it at an angle and then in the fixed one, probably you'll have to disassemble the MFP to have access and a better view of the parts.
Apr 27, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Encoder strip
Mar 28, 2007 | HP OfficeJet 4215 All-In-One InkJet...
HP Officejet 6600 e-All-in-One - multifunction  fax / copier / printer / scanner   color Logo
56 people viewed this question
Seeker5211
Seeker5211
