My Siemens Speedstreem 4100 modem is not working properly. It is 3 years old. It is working intermittantly so it cuts out once in awhile when using the internet. Can it be fixed? Could something else be interferring with it? If not, what is recommended to replace it for high speed DSL?
Try restarting the modem by either turning off the power button, or plugging out the modem power.
If the internet still frequently disconnects, it is most likely your ISP's (internet service provider) problem. Call them up with this issue, and they should either re-activate your internet for you, or give you a replacement modem for free.
Hope this helps, please rate and leave a comment ^_^
we are using aSiemens Speedstream 6520 router (Supplied by Telstra)which connects to three...
(More)
we are using aSiemens Speedstream 6520 router (Supplied by Telstra)which connects to three computers. 1. PC one works with the Netgear adaptor supplied by Telstra 2. PC two picks up the signal using a internal G-Link card (after setting up the network connection manually) 3. My laptop has a Intel wireless card and does not pick up the router, Ihave tried to connect to the Router using a netgear WG111 USB adapter (after downloading the Windows Vista Driver) again the Laptop did not pick up the routers signal. I have since tested the laptop and it pick up 4 networks in a local area so it appears the wireless card is working. Any advice
speedstream 6250 just need driver as i cant conect to internet with that computer driver detectives...
(More)
speedstream 6250 just need driver as i cant conect to internet with that computer driver detectives no good as i cant conect to internet please
never had this speedstream 5100 on my computer befor and do not have the disc for it. I there still...
(More)
never had this speedstream 5100 on my computer befor and do not have the disc for it. I there still a way to make it work
