Question about Sharp AQUOS LC-42D85U 42 in. LCD TV
Green spinning circle on tv - Sharp AQUOS LC-42D85U 42 in. LCD TV
Will read disc but the controller keeps spinning in green circle
there is a button on the top of the controller.and there is a tiny circle button on the console by the disk thing.press those buttons at the same time and it sould work. OR you sould replace the batteries.
Dec 20, 2009 | Microsoft Xbox 360 Console
Sony wega 28 inch colours wrong, circle on screen
It sounds that there is some magnet near by TV that is affecting picture tube. Please remove any extra speaker or any thing that has strong magnet inside, unplug TV for 20-30 minutes, replug back in, turn it ON, hope that will solve your TV problem.
Thanks.
Nov 16, 2009 | Sony WEGA KV-28HX15 28" TV
Screen series of coloured circles
The degusser is out .
When you turn the set affter its
been off awhile it makes a thud sound
and demagnatizes the tube thats
the degusser working . cost to
fix verries on makes 40.00 80.00
on 27"
Jul 01, 2009 | Televison & Video
Need information about an old ASKO 10604 washing machine
Hi there, we have a 10505 machine and the controls must me pretty much the same. The green E is "Economy" button - increases main wash length by 22 minutes so you can use cooler water. The two circles with diagonal may be a spiral with diagonal if you look real close - this is "No spin" button - no spin in any cycle. The 800 button - when pressed reduces spins speed to 800 rpm from 1000 rpm. Not sure about cold clothes though. Do you have the hot water connected? Have you got a temperature dial? If so, make sure you dial up the required temp. Good luck!
Cheers, Brian.
Jan 23, 2009 | Asko W6021 Front Load Washer
TV KOLIN 21"
hello.... do you have any speakers near your television? what color is the circle your talking about? Do the green,pink colors are scattered all over the screen and specially on the corners?
If you have or had speakers near your tv? then do this try to get a magnet.a magnet on a speaker would do.what you have to do is to place the magnet near the screen of the tv approx. above the green,pink color (turn it on first).you will notice the that the color will react with the magnet try to pull it on the side you will notice that the green,pink color is moving on the same direction do it until its gone.NOTE make sure youll not scratch the screen ok.email me what happened. jaredreyesbalderama@yahoo.com GOODLUCK
Jan 21, 2009 | RCA 20F512T 20" TV
Spin Basket Spins Along with Agitatdor in GE Profile Washing Mach
if washer is newer version remove front panel and ck if has a gearcase it's probably bad if it has what ge calls a mode shifter it's probably bad it has a coil with connection to motor bd..look on bd for flashing green 4 flashes means open mode shifter coil
Dec 17, 2008 | Kenmore 24032\24036 Top Load Washer
Sony KP-57HW40 57 in. Green Circles
well just remember the in the electrical industry its not 100 percent all of the time. you might just want to buy a new one.
Apr 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Green circle on the screen when I turn off TV
there is something really something wrong with your tv.try to reheat the main board.
Oct 30, 2007 | Sony KV-27FS13 27" TV
Green is not being displayed on my TV
If you have experience troubleshooting solid state TV sets, you should be able to tell by a couple of voltage measurements if its a problem with the picture tube or the drive circuit. Simply take the multimeter and compare the base voltage of the green drive to the red or blue drive transistor. If the voltage is about the same, measure the collector of all three. if the green voltage on the collector is higher then the others, then theres an open between the drive transistor and the crt element. this could be an open resistor, a bad solder connection on the crt socket, or an open picture tube element. If theres no voltage there then your going to have to trouble shoot the drive circuit.
Sep 08, 2006 | Toshiba 32AF41 32" TV
Sharp AQUOS LC-42D85U 42 in. LCD TV Logo
24 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
