Question about Acer Veriton Computers & Internet
Wont boot up, restarted by itself keeps getting a message saying - pre preparing your computer for first use, install windows, computer encountered an error, windows installtion can not proceed please resstart your computer
    Master:
  • 568 Answers
Details needed
Posted on Jun 02, 2014
MJS_1
  • 150 Answers
SOURCE: When I switched on my
This sounds like a corrupted XP installation or possibly a damaged hard-drive, either through a hardware failure
or through file system corruption.
(the last scenario is the most likely)
Windows uses write back caching to improve performance.
This means that data is not immediately written to disk, but
the writes are delayed until there is enough data to make
it worth while.
Also, the NTFS system uses transaction based data transfers,
which set a dirty flag, write the data, update the file indexing
structers (MFT) and then clear the dirty bit on a hard drive.
If a PC unexpectedly looses power, or if it is hard reset during
a disk access operation, the hard drive may be dirty or
corrupted. For this reason, reseting or powering down a PC
without going through a proper OS shut down is a very bad
idea.
The correct procedure is START ==> SHUTDOWN ==> options,
and let windows do its thing.
Having said that, the NTFS file system is very robust, with
transaction logging and indexing redundancy, such that
it usually recovers from such events, by automatically
scanning and repairing the hard drive's index structure
when the system is re-booted.
For some reason, this has not happened on your machine,
and for some reason, windows is trying to re-install itself.
This may be due to and automatic recovery partition and
utility built into your computer. Most modern laptops have
a small, hidden HD partition, on which they store a rescue
copy of the operating system, along with some diagnostic
and recovery utilities.
This recovery mode is often activated by a special button
(such as the IBM BLUE BUTTON) or a bypressing a special
key combination during start-up.
1) Try completely powering down and restarting your machine.
Wait a couple of minutes after power down, then physically
remove the battery.
2) Wait a couple more minutes, put back the battery and
restart the machine.
3) If this does not help, you have one of the following:
a) Damaged operating system / aborted re-installation
b) Damaged file system through improper shut down
c) Hard drive failure
d) Bad settings in the BIOS or within the BOOT.ini file
causing the system to boot from an incorrect hard drive
or partition. (but this is unlikely)
At this point you need to call tech support for model specific
instructions on operating system recovery.
Martin
Posted on Apr 24, 2008
  • 90 Answers
SOURCE: I bought new laptop and
Try booting your system with the Windows installation CD.
Thank you.
Thomas
Posted on Nov 16, 2008
  • 192 Answers
SOURCE: I am doing a clean
Ok, first blets try and use the eRecovery program.
When you turn the system on, and it displays either the ACER logo or black screen with white writing, press F2 or Del to enter setup. It should display what to press in the bottom left corner of the screen.
This will open the BIOS settings. There should be a tab at the top called Main, select it. Somewhere on the list there should be something called D2D Recovery. Highlight it, and make sure it's Enabled. Now, while it's highlited, it will display what keys you need to press to start the recovery program. This is usually Alt+F10. Now save your settings and exit.
The system will now reboot. When the ACER logo or black screen with writing appears, press the keys that you saw in the BIOS. The Acer eRecovery program should now start. Follow the on screen instructions.
Hope this works, let me know
Posted on Apr 11, 2009
computer254
  • 31 Answers
SOURCE: I keep getting an error screen after a system
If this was a windows system restore try picking another date before the one you just carried out.
Its going into a loop because its missing some information ,or your restore method was not windows system restore but acer recovery only a drivers and OS system restore,try pressing F8 on start-up and see if it will boot into safe mode this should allow you to check all the drivers and also do a virus check which I suspect is Master Boot Record based, If the problem persists and you have no way even after trying out safe mode use complete Acer System Recovery to factory defaults this will then make a backup file on the desktop labeled windows old backup where you can then recover documents,music,photos etc
Posted on Feb 28, 2011
Testimonial: "Thank you. I have tried Safe Mode, Restore with keeping my files and a restore to Factory Original and all give me the same results."
SOURCE: I tried restoring my desktop
you need to clean your registry sometimes. uniblue registry booster works well. you can get it free from btjunkie.org and register it cause if you dont it wont fix ALL the errors just some. btw... you have to have utorrent or the like to dl it from btjunkie. it is a torrent. if that dont work then you might need to restore factory settings:(
Posted on Jun 01, 2011
I had to factory reset my tablet and after it factory reset it shut off and when it turned on again it said 'the computer restarted unexpectedly or encountered an unexpected error.
Help laptop wont start after resetting factory settings - Acer ...
www.tomsguide.com/.../77186-35-help-laptop-wont-start-resetting-facto...
Mar 25, 2012 - 5 posts - ‎2 authors
i restored my laptop back to factory settings as it kept crashing, now when i ... TVs · Cameras · Smartphones · Tablets · Software · 3D Printing; More ... or encountered an unexpected error, windows installation cannot ... then restart the installation... i do this and its just repeating itself, i have no recovery discs.
"The Computer Restarted unexpectedly or encountered an ...
heresjaken.com/the-computer-restarted-unexpectedly-or-encountered-an...
Feb 1, 2013 - Now your computer will restart and continue on the Windows setup process ... THOUGHT MY 1000 DOLLARS COMPUTER HAD CHRASHED AND .....setup experienced an unexpected error" To install windows, restart the installation. .....JUST fyi - I had a similair problem on a Surface Pro 3 tablet and this ...
encountered unexpected error when going to factory reset ...
h30434.www3.hp.com > Laptop & Notebook > OS/Recovery
Jan 13, 2016 | Computers & Internet
Packard bell zh7, had virus did reboot ,now has message which reads,The computer restarted unexpectedly or encountered an unexpected error.windows installation cannot proceed.To install windows,click ok to...
You are going to have to use the restore/recovery process to get past this. The virus corrupted a major file and now it wont boot. I hope you made backups.
Oct 28, 2013 | Packard Bell Computers & Internet
Setup is starting services it say start up will resume when restarted then it restarts then says the same thing over again
My computer did that once, just before it crashed. I had to go into the boot menu and choose a different start boot. (Ctrl-Alt-F10 I believe that's the boot menu access. It's been a while, but it was either F10 or F12) This will cause your computer to reset the boot app and start from scratch. You will lose all your data, but it may be the only way to get the computer to work properly.
Feb 16, 2013 | Acer Aspire One Netbook
I have a msi a6000 laptop and it keeps shutting off itself and wont boot windows when windows stars booting it shuts off and i clean the fan so thats not it can someone tell me what it's hapening
try replacing the thermal grease on your cpu.
the BIOS have a protection that restart or shut down the computer/laptop when the cpu get to hot.
You can also check if the power suply is working in parameters
Dec 06, 2012 | MSI A6000-226US Core 2 Duo T6600 2.2GHz...
First time start up error message
indicates a problem hard drive not allowing the boot up to complete
take it to a computer repair shop for a proper diagnosis
Apr 24, 2017 | Fujitsu LifeBook AH531
Computer restarted during restore while trying to install windows 7 now wont work. An error pops up saying...... The computer restarted unexpecttedly or encountered an unexpected error. To install windows...
hi Mike.
this is all i could find.
Try the following...
1. Power off the laptop.
2. Power on the laptop.
3. As soon as you see the rotating loading circle, press and hold the Power Button until the computer shuts off.
4. Repeat this process a few times until you see the "Preparing Automatic Repair" screen.
5. Now you want to let the laptop boot to the "Automatic Repair" screen.
6. Click "Advanced Options" and then select "Troubleshoot".
7. Here you want to select "Refresh your PC", if you do not wish to erase data, or "Reset your PC" to erase all data and restore your system.
8. From here just follow the screen instructions until the recovery is completed.
NOTE: You will need to get into the "Advanced Options" in order to get the "Refresh Option". This choice will keep your data, but any programs installed will be lost.
Do not do a "Reset" as that will wipe all data you have on the laptop.
or go to this link and read up in the forum might help.
My laptop keeps restarting and installing windows how do fix this
if that does not help you go to this link.
Toshiba Satellite L655 S5096 Notebook Computer restarted during restore...
Nov 22, 2017 | Toshiba Satellite L655-S5096 Notebook
Brand new laptop and when switched on for the first time message pops up during setup. It says 'the computer restarted unexpectedly or encounted error. Windows installation cannot proceed. To install...
try reseating memory modules, see if nay change, if no, then try the modules individually, one may be bad.
Try running system in safe mode (F8 at boot) see if it will get past issue
Dec 25, 2010 | Computers & Internet
Ntldr is missing
Check the connection between the hard drive and the motherboard. When you get the NTLDR warning, it is telling you that the hard drive is not being read. There maybe a failure with the hard drive itself.
Jul 10, 2010 | Computers & Internet
Unable to get pas message at bootup
I am sorry to say but seems like your system perhaps the Windows system files got corrupted. Boot your computer up to the Windows CD and run a repair. If this does not do it, you will have to reinstall Windows again.
Apr 09, 2009 | Everex StepNote NC1500 Notebook
Satellite a300 wont install windows (brand new)
turn off the computer and disconnect the battery . wait like half an hour. put it back in you have to wait a few minutes for the battery to finish charging then turn it on . this should help. the menu will pop up after you type your password in .
Mar 15, 2009 | Toshiba Satellite A300-0CF035 Notebook
Computers & Internet Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
