Emailxtract - need to open message - Audio Players & Recorders
How to delete a sent message s3
To remove a sent text messaging in SamsunggalaxyS3: Open the Messaging app. 2. Tap and hold the message thread until a menu appears. 3. Select Delete thread. To delete individual text messages from Samsung Galaxy Tab: 1. Open the Messaging app.2. Select the message thread that contains the item you wish to delete. 3. Tap and hold the message until a menu appears. 4. Select Delete message.
Dec 05, 2012 | Apple iPhone Cell Phones
Not enough volume to alert me when messages come through
All you need to do is to increase the level of the ALERTING tone when the message comes into the machine. So open Menu> Settings>tones> open message alert tones and select appropriate tone and highest volume.
Aug 18, 2011 | Cell Phones
I couldn't open my messages and a message is coming that your message is corrupted, how to sole this problem
What kind of messages are you trying to open? If it's a text message, then you may need to upgrade the firmware of your phone.
If it's an email message, you need to access the web mail and make sure that the messages are not corrupted.
If you're accessing your email via the web browser of your phone, try to upgrade the version of your web browser. But if you're accessing the email via the phone's email client (POP3 or IMAP), delete your email account from your phone and re-create it.
Thank you!
Dec 06, 2010 | LG GM200 Cell Phone
How do i transfer all the messages to PC from Nokia 2626 mobile phone.
You will need to install nokia pc suite on your computer system before you can be able to to do this.
Install nokia pc suite, after installation, connect your phone to your to your computer system, open your nokia pc suite on the desktop and click on message on it the pc suite to open all your messages.
Go to edit at top left corner of the pc suite, open you will see select all, highlight all the messages and copy.
Now go to computer system desktop and create a folder you want to store the messages, open the folder and right click to paste all the messges,.
Safely eject your phone. you can now view all your messages on your computer system.
Take care.
Apr 26, 2010 | Nokia 2626 Mobile Phone
Cant open any messages sent to my phone inbox
You need to check the settings then .....
Message > Menu > Message Setup. Fill in the required and you should be away.
Master Clear and Master Rest get rid of all your pictures, ringtones, videos and address book
so beware of this !
Aug 06, 2009 | Motorola Mobility HS850 Consumer Headset
Unable to send text messages on my new nokia 5800
All you have to do is go to your message setting on your phone:
1. Open Messaging
2. On New message sellect options at bottom
3. Open settings
4. Open Text message, you should see: Message centre, message centre in use ect..
5. Open message centres this should go to next screen then open again, this screen should have : Message centre name & Message centre number (from your network provider you need to find out what is the message centres name & number are e.g in Australia it should be SMSC1 and number is +61411990001) then just manually enter these in there.
Feb 26, 2009 | Nokia 5800 XpressMusic Smartphone
Sending text sms messages from tytn II
I had a similar problem found solution today:
first you need to obtain your messaging service centre number from your networ providor, like Vodafone-TMobilen-Orange..etc
Then follow this process:
Press for menu, press messaging, press options, press settings, press options again, press open, select message centre then press options, press open, press options again select open go to message centre number and insert the number you have obtained at the beginning your sms sending will be activated...
Jul 13, 2008 | Nokia 5800 XpressMusic Smartphone
My NOKIA E62 does not let me open text messages, or send text messages
i m not able too send or rec. messages through nokia e62....even i have entered the required message center no. but no use ...even i have done formatting & flashing... but no use
Mar 06, 2008 | Nokia E62 Smartphone
PANASONIC EB-X701
Hi
SMS Message Settings
From Messages menu:
    1. Press Options and select Settings.
    2. Open SMS.
    3. Open fields as needed:
Get the details reg. message centre number from  service provider
bye
Was my tip helpful?
Feb 10, 2008 | Cell Phones
Open Questions:
75 people viewed this question
 Grubhead
Grubhead
