Question about Whirlpool Cabrio WTW7600XW 27" Top-Load Washer
Whirlpool cabrio lid springs replace - Whirlpool Cabrio WTW7600XW 27" Top-Load Washer
  • 530 Answers
SOURCE: opening top of cabinet
you have to use a putty knife. It is a pain in the neck. there are two clips where the top of the cabinet is there is a slot you can see the clip if you use a flashlight push theputty knife in and pull up. Then do the other side. They are directly in the frontt of the unit
Posted on Jan 04, 2009
  • 530 Answers
SOURCE: Whirlpool Cabrio WTW6600SW0. I need to replace the lid but ...
do you see about 2-4 inches down a crease that runs all the way around the top?
there are 2 clips in the front you need to push in with a putty knife and lift the whole top up.
if you where to look at the very left corner and go about 5-6 inches in you will find the clips.
can be a pain.
make sure when you do lift the whole top that you hold the lid or it will crash into something.
let me know if this helps
Posted on May 12, 2010
bbl242003
  • 1637 Answers
SOURCE: I have a whirlpool cabrio washer wtw6200sw2 and
Welcome to fixya
I have a solution for this
Content
The error code your seeing more than likely is associated with the systems wash cycle. If your unable to wash at all, then the problem is located beyond the lid lock wiring.
Your pre-solution is located above. More information is available in the comments
My name is Bruce
Posted on Jan 20, 2011
  • 403 Answers
SOURCE: the load finished on my
you need to replace the lid lock. the latch probably broke in 2, and the broken part is whats keeping the lid closed. if you have clothes inside you can open the top by using a putty knife to release the front clips holding the top of the machine down. push each clip in and lift up. you will also be able to access the lid lock this way.
Posted on May 05, 2011
SOURCE: I need the service manual
how do i open the top of my washer whirlpool cobrio wtw66003w2
Posted on Dec 24, 2011
Cabrio wtw7800xl2 Lid frame beaks! Want TO Replace
You can try going to repair clinic at repairclinic.com and probably get the lid along with video help.
Aug 05, 2015 | Whirlpool Washing Machines
Lid problems
If you are using the box to keep downward pressure on the lid because it won't stay closed, you most likely need the left and or right hinge/spring unit replaced, these retail for about $57.00 each. You have two dispenser compartments in the rear left and right, since the bleach is on the left, it often causes rust on/within the hinge assy either from disect splash, or from vapors. If the rear lid trim has come un glued from the lid and the lid is very flimsy, than the entire glass lid needs to be replaced. These retail for about $215.00. Pleazer Appliance...
Apr 19, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Lid will not stay up like it did before
Sounds lid the hinge or springs may be broken need more help contact me
Mar 29, 2014 | Whirlpool Cabrio WTW7600XW 27" Top-Load...
Glass separating from lid
Replace with steel lid. Parts below but first I have to get my 2 cents in!
I bought the replacement glass lid and it broke within the first week. Terrible design! They are using double sided tape to hold the glass to the hinge. There is too much spring tension to be held with tape. Way to go whirlpool engineers. I'm just a welder with 1 year of school and I figured that out? Hmmmm?
Steel lid retro fit
Whirlpool will tell you it can't be done. However I did and it works and looks perfectly.
here's the parts you need
All from a WTW8200 series washer
Part prices from Sears. I'm sure you can find them cheaper elsewhere if you look. I bought from sears to utilize the return policy while figuring out what parts to get. Thanks Sears! Give them the business if you can!!
1 pc 8572026 Steel lid $40.90
2 pcs 8563964 hinge $6.99 ea (hinge from the glass lid are different and the screw holes won't line up)
4 pcs W10119828 $3.99 ea (could probably get from the hardware store for half the cost.
Solution 2:
buy a replacement glass lid from whirlpool and send them your broken original glass lid and get a refund for the one you just bought. Repeat as needed until they figure out they need to produce a quality product.
Keep your whites...White and your colors bright America!!!
Nov 20, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Lid
The lock cannot be disabled, The lid removes easily and is also simple to replace.
Depending on where in the world you are depends on where you will get a lid, If you do a google search in your area for whirlpool spares you will get some results.
Mar 10, 2012 | Whirlpool WTW6400SW Cabrio Washer
MY CABRIO SAYS DU ON THE SCREEN AND THE LID WONT LOCK IT JUST CLICKS THEN STOPS AND WONT LOCK IS IT AN EASY FIX AND CAN I DO IT MY SELF?IM VERY MECHANICALLY INCLINED AND IT SOUNDS LIKE THE SENSOR IS BAD IS...
The top has spring clips that hold it down. The lid lock has 2 screws you remove.
Print this service manual out 84 pages 16 megs lid lock replacement is on page 46.
I have it set for anyone on the web to view but sometimes it take a couple try's to download. Aggravating internet mess.
Jul 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio wtw6600sw2 has error f54. what does it mean and what can I do to fix it?
you can locat the tech sheet by lifting the lid
you will see a **** that goes all the way around the washer
to the very left and right corners in the front about 4-5 inches you will find 2 clips
push in on the clip and pull up
do both sides it is sort of tricky
maybe have someone help you one person to hold the lid so it does not spring back and break
you will find the tech sheet to the left inside a plastic shething
Aug 24, 2010 | Whirlpool Cabrio WTW6600SBK
can be a pain.
May 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW7600XW 27" Top-Load Washer Logo
93 people viewed this question
Dan Webster
Dan Webster
Sal De
